The inners were tight. After snugging everything up as tight as I felt possible without snapping anything, I remounted the tire and took her for a drive. No more pulling! Not sure I got the association between the steering arm nutz and trunion bearings?
just went out and checked the studs & nuts. axle job about 10k miles ago. Should there by grease on the nuts? almost like someone glazed over them with some WD-40 (thats what it looks like anyway)
Properly greased knuckles weep a little oil from the grease. The studs/nuts are the lowest spot on the knuckles, so it's common/normal to have some residue on them. But when in doubt the best plan is to grab the torque wrench and click them, I always check them a couple of hundred miles after a knuckle job, before and after big wheeling trips, etc.
thanks very much. i was able to get a little movement on them when tightened down tonight. i need to get an 18mm open wrench so i can get at the bolts closest to the brake guard. i am glad y'all revived the thread, thank you.
You might want to make that a 17mm wrench, or you'll be there a while![]()
