I installed 8 new knuckle studs on the last birfield service. Installed with blue locktite and torqued to 50 ft/lbs using new nuts. Reused the cone washers.
I occasionally put a wrench on mine to check them, but i'm thinking when i do my next front axle service i will locktite the nuts on the bottom of the knuckle just to ensure this will not happen.
It may be like puting dirty shorts back on, but to save an extra $100 by re-using bearings that aren't worn out seems like a pretty good compromise to me.
I probably should not bring this up, but when the studs get loose, they can wallow out the threaded hole making it unusable.
Just me, but I would take it fully apart, R&R the studs on the bench and replace the bearings if they really have 40k on them. If the hole or the threads are boogered up, you will need a new knuckle. I'm sure they will be reasonably priced from Mr. T.
Part of your routine should be periodically putting a torque wrench on your nutz and making sure they are tight. The spec is 76 as mentioned, but I go 80 and have not broken one yet. ARP also sells stronger studs for this application if you would like. They are spendy, though.
Still, a full rebuild makes sense to me with 40k on the last one. if it had say 10k, then I would agree with you.
Just to be clear... as Dan said, the studs get the loctite into the knuckle and torqued to ~50 ft/lbs. The nuts get torqued per spec which is probably what Drew said because I cannot remember.
-B-
Fine. You fookers talked me into it. New bearings! (they weren't that expensive, it's the wheel bearings that kill you.).
New gaskets, trunions, HD inner oil seals, etc... for both sides.
Oh, and the baby will be here next week so I doubt I"ll get this done anytime soon, but I've got to get it done before the TCCC08 which is mid-August. ARGH.
holy cow, you got lucky it did not fail befoe you got in the drive way!!!!!!! anyway may want to buy 4 extra studs and washers and keep um the tool box so if your out you have a few spares.
-B-
The only ones that you can get a socket on (when everything is assembled) are the inner ones. You can get an open-end wrench on there and check to make sure they are not loose. Of course the torque can't be verified.
Sort of true but you can get a short socket and a wobble extension on there. It obviously affects torque readings a bit, but not enough to matter. They need to be very tight, and the integrity of the fasteners checked on a regular basis. If you take your truck wheeling, it's best to check at the end of every wheeling day-thanks Pismo Jim for that lesson way back.
I am paranoid after seeing the knuckle stud/steering arm junction fail on practically every run I've gone on, including recently Chris Hatfield at Rubithon, and a minitruck guy last weekend at Fordyce. The kid at Fordyce was most instructive-he had spare studs, put them in and they pulled right out-the threads were that boogered. He needed a whole new knuckle out in the middle of nowhere.
Maybe Slee can make a 6 stud version of the 80 series knuckle, similar to the 6 stud knuckles from Trail Gear.
The fundamental problem is assembling the knuckle with loose studs. If the studs are properly tightened in the knuckle I think the majority of these failures would go away.
Now put one on 37's and run Rubicon a few times and I could see a potential problem there.
I have switched to ARP studs on my knuckles. I recheck the stud for tightness every time the front ends apart enough to and I throw a wrench on the nut and give it hell every day before hitting the trail...
I finally got all my parts and re-built the front end yesterday.
I do have to say, those new Marlin Crawler inner oil seals are the shizznit. I also like the peace of mind the new knuckle studs provide, very easy to tighten now. I gasoline'd out the holes and lock-tite'd them in place so hopefully I won't have this problem again.
A word on the stock knuckle studs. All 4 on the passenger side spun out of the knuckle with just finger pressure, no wrench needed. I had a harder time getting the nuts off of the studs once they fell out of the knuckle than getting the studs out of the knuckle.
