- Thread starter
- #61
What is a good way to check and tighten the knuckle studs when everything is apart for a front axle job? Should they be taken out and then locktite'd back in if they are loose?
If you have the FSM you can check the torque rating and check 'em that way. If they are loose, you should absolutely remove them, clean the threads with gas and locktite (new style) studs in their place.
