- Thread starter
- #21
Pin Head,
In the passed i have always had at least 14.3volts at my auxiliary battery in the tray which runs our fridge.
I discovered this 'issue' because when running the fridge, even with the engine running i was getting voltages as low as 12.5V at the fridge - again when in the passed its been 14.2.
Couple that with the ammeter bouncing all around the place and into the -ive makes me really believe something is wrong.
The reason for bypassing the ammeter seems pretty logical, its not acting normal so i thought perhaps it might be 'broken'. The reason for simply removing one wire from one terminal and bolting it up with the other is it is the safest and simplest way of bypassing the ammeter without have a full power active wire 'loose' behind the dash taped up.
Once im sure it is not contributing to the problem i will wire it back up properly.
Our old alternator and even this new one has on many occasions easily powered the vehicle, headlights and spotlights (say 30-35Amps) at 14-14.5volts which i expect. Dropping to 13volts while the engine is running at speed is not ok with a load well within the specs of the alternator.
Monitoring the field wires voltage seems to correlate with whats going on. When it is working 'right' and supplying enough power to run the spotlights at 14+ volts the field wire is "X" volts... When the output seems to be acting up the field wire is a completely different voltage.
tbc
tbc
