G'day guys, for the last month or so ive been quietly battling some electrical demons in the ol FJ45!
Basically the symptoms were:
1. it wasnt charging like it used to.
2. the ammeter would on occasion (more often now) go into the -ive zone, something which it has never done before.
So, i started out looking in all the obvious places for bad fuses, grounds and voltage drops. The fuseable link... Ive been disconnecting plugs, terminals etc. and cleaning all of the contact surfaces.
In the last week ive gone out and purchased a new Voltage Regulator and Alternator. Nothing has really changed. My Voltage Regulator is the original mechanical type. 3 wire. Switched +ive (source / IG), -ive and field. Ammeter is the -30 / 0 / +30. B wire from the Alternator runs around through the firewall through the ammeter then back out to the battery.
Ive read literally a hundreds of posts here on anything remotely relating to what i think is the problem but cannot for the life of me sort it out.
As best i can tell my wiring is almost exactly as per Jayson Peters 1978 FJ40 wiring diagram in the Tech Links (obviously no Emissions Computer, no rear heater, seat belt warning, cooling fan or radio...) however i believe my coil is wired as shown in: Chris Kantarjiev (1971 FJ40 Wiring Diagram)
What i have found (however im not sure if these results are NORMAL or not)... i have around 1volt of voltage drop on my ignition switched (IG) circuits. Is this normal?
I do not believe anything is wired to the ACC circult on the ignition switch? I do not have a radio in the old Yota.
Today i tried documenting the different voltages. In order to get a consistent voltage level through the duration of my 'tests' i hooked the battery up to a Mains 12V DC supply.
The supply voltage was fairly fixed at 13.7Volts.
So, at the battery terminals i had 13.7V.
With the ignition switched off, on the unswitched circults (lights, stop lights, lighter etc.) i had 13.68V. Ammeter is sitting in the normal centred (0) position.
Turning the ignition to on, cause the voltage on these unswitched circuits to drop to 13.37V.
Then measuring the switched circuits showed they were at 12.75volts and the ammeter showed the usual -ive 5 to 10amps?
Im not sure if i know what all of the sources of load are but with the key in the ON position there is the Coil, the fuel solenoid and the voltage regulator. Is there anything else????????
The coil is supplied from the supply side (no fuse) of the ENGINE fuse on the fuse block and the fuel solenoid and voltage reg are supplied from the fused side of the same ENGINE fuse.
However, when removing ALL fuses, and removing the +ive wire from the coil there is still a -ive load shown on the ammeter when the key is in the ON position.
For the sake of it, i measured the load across the ENGINE fuse with the key in the ON position. 3.5A with both the voltage reg and fuel solenoid connected, and around 0.15A with just the fuel solenoid connected.
I then checked the voltages at the Ignition switch looking for a voltage drop upstream of the ENGINE fuse etc... With the key OFF the continuous active there pretty much matched the battery terminal voltage and was the same as the unswitched circuits voltage at 13.68V.
Turning the key ON saw the same terminal voltage drop to 13.14V and the IG terminal became active and had 12.97V.
I then pulled the ENGINE fuse and checked these two terminals again. The supply terminal without the engine fuse jumped up to 13.41V and the IG terminal without the engine fuse was 13.32V.
I checked the coil at the same time and it was 12.57V with the ignition switch ON, and 13.1V with the ignition switch ON and the ENGINE fuse removed.
It seems to me that something is wrong with the sense wire (IG) to the Voltage Regulator. If i start the car the voltage will slowly climb to around 14.2-14.8 volts and with some engine revs it will climb to 15.2V.
If i create a load for the alternator ie. turn on the lights and spotlights (2X100W) the voltage will sit around the 14volt mark, sometimes higher 14-14.8V. It seems like everything is kinda ok but the voltages move around a bit...
But if i go for a drive with no additional loads (headlights off) as soon as i slow down the ammeter will start showing a -ive load and the voltages on the fuse panel (both switched and unswitched are around the low 13V mark, 13.1-13.3V).
When this happens, if i check the field wire from the voltage regulator the voltage hovers around 3-4volts. With the electrical system still in this 'state' if i then turn on the lights the ammeter will go back to center and the field wire will read around 5-6volts, then if i turn on the spotlights the field wire increases to around 7-8volts.
However when the charging system appears fine, the field wire voltage is completely different. 6-8Volts with no load and 12-13volts with a large / full load??????? IIRC.
With the engine running i tried 'jumping' the source wire (IG) on the voltage regulator directly from the battery. This resulted in the alternators output becoming quite consistent, it pretty much sat at 14.1Volts. Lights on, off etc... further making me think it has something to do with the supply wire to the voltage reg.
Ive tried checking the wires between the voltage reg, the engine fuse and the voltage reg and the alternator and they all test fine. no signs of abnormal resistance anywhere. All plugs / connections are good.
I also tried connecting a ground wire directly from the battery to the voltage reg which did nothing.
IMO it doesnt make sense
Can anyone think of what else i would have connected to the ENGINE IG circuit. As above, with the fuse out and the coil itself disconnected when the ignition switch it switched to ON, there is still a -Ive load showing up on the ammeter. Even if i pull ALL fuses out of the fuse panel (and the coil disconnected) there is a -ive load on the ammeter!)
Im sorry if this is all over the place, ive tried to test everything i could think of before asking here and as a result my 'findings' are a bit all over the shop and no doubt hard to follow. Id say ive left a few things out to.
ANY thoughts would be greatly appreciated.
(My only thought right now is to disconnect the old Source wire to the voltage reg and using a relay connect a new wire, supplied from the battery, switched from the ignition and see what happens... Naturally i dont want to do this because i would rather find the cause of the problem.
Travis.
Travis.
