G'day guys.
Rudi, great find re: the old post by coolerman.
However what he says doesnt really match up with what we see in the wiring loom photos, they both clearly show thicker WB wires extending out of the loom and terminating into a Lug terminal (ring terminal).
https://forum.ih8mud.com/40-55-series-tech/430560-fj40-wire-harness-reference-september-1976-a.html
https://forum.ih8mud.com/40-55-series-tech/475291-fj40-wire-harness-reference-december-1978-a.html
They show 2 or 3 'grounds'. One near the main fuse panel and one or two outside in the engine bay.
I cannot located any of these 'grounds'. I know these photos both show Left hand drive versions, and FJ40 as opposed to FJ45, but id still have expected my loom to be similar. But now with the information from Coolerman, i dont know.
What coolerman has posted fits perfectly with how it seems my old cruiser is wired. To be honest i just do not believe the previous owner would have done anything not factory to the old girl. He did such a good job with the old girl - which he had for over 20years, he just didnt seem like the type to 'leave out' or remove something which is there from the factory.
Re: the wires coming from the loom to the voltage regulator... There are only 3 wires coming out of the loom and they all connect to the VR. There is the BY (source), the WG (field) and WB (ground).
With the original VR, there was / is no ground wire connected to ground via a Lug terminal / ring terminal. Again, 3 wires from the loom, they all connected to the VR via a 3 wire plug as can be seen in my photos above.
However, now that i have switched to the Solid State VR - a 2 wire type, i have simply fitted a Lug terminal to the WB (ground) wire from the loom and fitted it under one of the VR mounting bolts.
Ed - ive never seen a lug / ring terminal connected at the VR. Other then the 3 wire plug, or 6 wire plug at the VR's on these cruisers the only other thing which is 'sometimes' there is a condenser fitted under one of the VR mounting bolts - other end comes from the source wire. (My old girl has never had a condenser fitted here, thus i never bothered trying one however as this problem as drawn out i did start thinking perhaps its another thing i could try).
I was going to post a little update the other day but thought ya'll might have been sick of my drama here!
Having driven the vehicle a couple of times, and also at night using the headlights etc. i was happy that the S/S VR was performing well and i would wire it up nicely with a proper plug connecting it to the plug from the wiring loom. The one half of the plug which is connected to the wiring loom is OLD and original, but its buggered so i wanted to fit a whole new plug, to both the loom and my wires connecting the S/S VR.
So i went down to the local auto parts store and purchased a 3 wire plug kit and went home. Trying to cheat a little i thought if i could remove the old terminals from the old original plug which was badly deteriorated and quite brittle etc. then it would save me having to strip the short wires there coming out of the loom and fitting new terminals etc. It really is quite a tight working space there behind the air filter housing / carby / manifold etc...
I tried and tried to get the terminals out of the old housing but in the end i had to give up. I really spent quite a bit of time trying to get the terminals out and even custom made a nice little tool by grinding down an old screw driver to try and depress the tab on the back of the terminal which keeps it inside the plastic plug. However it wasnt meant to be so i got out some big pliers and started tearing the old plug open to get the terminals out... But given the restricted working space i was only successful in removing two of the 3 terminals, so i had to just cut the old terminals off!
I then opened the new 3 wire plug kit only to find i was missing 2 terminals!!! It contained 2 male and 2 female terminals instead of 3 of each. I was seeing RED!
I was going to call it another day as i was already hurting from the fight the old girl put up as i tried to remove that old plug.... I went and made myself a little drink (whiskey and coke) then decided id better just rig it up quickly so i could drive back down to the auto parts place and ask them about the missing terminals!
The guys at the auto parts store gave me a few new terminals and i was on my way. (Note the male terminals used in these plugs are longer then what id call 'standard' terminals... i have got thousands of terminals, lugs, connectors etc - my dad is / was an electrician but again these lugs are longer hence i had to either go but another plug kit or see if the guys had any loose they would give to me).
Now the real fun would begin, i had to crimp all new terminals to the short wires coming out of the wiring loom. It was a pain in the butt but i do pride myself in being able to work in the worst and most confined spaces - it helps having little girly hands!
After blowing what seemed like half they day on what most would call an hours job i was finished, and happy with the new wiring / plug and i got ready to fire up the engine and check all the connections and function of the VR.
Engine started, all the voltages seemed sweet... THEN, i tried turning on the headlights and... i got nothing!
I really nearly threw a tantrum lol. However i pulled myself together and just started methodically going over everything.
Firstly, the obvious thought was that while working on the wires for the VR, id disturbed whatever wire / connection it was / might be thats the cause of the entire issue. With the engine on and headlights switched on (but not working) i tried pushing / pulling / squeezing the wires in and around the loom where the VR wires come out. Nothing.
Using the little ground jumper wires id made up the other day i quickly connected them up but it had no effect. I then tried checking the voltages etc. However this time i had 0V at all 3 terminals on the back of the headlights, regardless of the headlight switch position - low beam / hi beam.
Slowly i worked back to the Fuse panel. Headlight fuse, check. Looks good. Checked the voltage, good. Checked it again 0V, checked it again 12V, again 0V... WHAT THE! farken hell i couldnt believe it. Obviously the old glass fuse had broken internally. Of course, i have plenty of spares, but you bet... getting to the would be another pain in the ass!
New fuse = headlights back working perfectly!!!!!!!!!
Seems the old girl is really enjoying messing with me right now.
So, the S/S VR thus far continues to work almost perfectly. The output voltage from the alternator is absolutely consistent. At idle, rev's, no load, load the voltage is always within 14.0-14.4V at the battery.
The indash ammeter is almost back to 'normal'. Driving around it holds nice and steady, with additional loads (headlight etc) it holds steady at the appropriate position in the +ive area. Only briefly every now and again, when im stationary - foot off the brakes (so no other electrical load other then just the running of the engine) the ammeter needle will just 'vibrate' a tiny bit back and forth a wee little bit (never into the negative tho).
So id say its working 99% perfect, however i am still bothered by the unknown wiring loom ground situation.
Rudi, numerous times ive tried connecting a 'new' ground wire directly from the battery -ive terminal to the VR housing. This had no noticeable effect. (This was all done with the Mechanical VRs only).
Travis.
