- Thread starter
- #41
Heya Rudi,
A while ago i did try running a direct ground wire from the battery to the voltage regulator as well as the standard wiring. What i mean is i left everything wired up as per normal and then simply ran new single wire directly from the -ive battery terminal and connected it to the housing of the voltage regulator (alligator clip to the mounting bolt through to the firewall).
I also did the same with the source wire to the voltage regulator. As per the ground, it was 'as well as" the original wiring / source wire. Neither the additional ground or source fixed the problem.
However i dont know what the effect is of running these wires 'as well as' the originals. My belief was if there was a bad ground - back feed power through ground going into the voltage regulator then by adding an additional ground wire directly to the battery any back feed power would take this route to ground and stop effecting the voltage regulator.
So i guess the next step is going to start fresh and actually run all new wires, and then one by one swap back to using the old wire. So ill have to do this for the Source wire, Ground, Field and maybe the B+ wire from the alternator to the battery.
With regards to running a 'new' B+ wire, will it be ok to simply disconnect the factory wire from the back of the alternator, then run a new wire from the back of the alternator directly to the battery leaving the rest of the original B+ wire in place.
My thinking is this would at least rule out something being wrong with the factory wire between the 't-off' where it splits from the alternator, one going to the Ignition feed, and the other branch going via the ammeter to the battery via the fusible link. Or not, im just not sure how i could isolate the ignition / engine running circuits from the alternator in case there is a problem with them causing the problem.
Re: the DMM beep testing, i went back out to the garage before and re checked the Field wire, Ground wire and B+ wire up to the firewall, this time manipulating and wires, shaking them around, pushing on them, twisting them etc... this had no effect, no faults turned up.
Ive just taken a quick video to share, it the first one ive done in a long time, so it was really just a test to make sure i was still able to upload a video to youtube with my current camera etc.
So now, if there is something anyone wants me to test and video i can show everyone the results.
Travis.
Travis.
Pffffffft.
