So I read a bunch of threads last night about which weight oil to use and which filter and so on and so forth. I like the idea of running something quite heavy duty as I have 255k miles. I have come to the conclusion that I'll use the Shell Rotella 15w40 diesel oil ran through the WIX 51515 filter. The idea of running diesel oil in the gas engine seems weird to me, but apparently a lot of people do it. Just wanted to make sure this is an alright combination. Thanks!
Been running mobile 1 diesel synthetic since my engine rebuild. I hate yet to hear someone say, "Brand X was the worst oil I ever used in my truck, here's why..."
330k on the clock. Running rotell 15w-40 for years now. Keep trying to fight it and use other oils but she always lets me know the error of my ways. Puralator one 30001 filter.
Use to run 15w40 in my Jeeps. Was worried that during the winter it would get too thick on start up. What temp would cause folks to worry about viscosity using 15w40?
I just changed some old unknown oil from the PO, which didn't look too bad because I was adding a Qt every 1-2k or so, to Rotella T6. Funny thing is as soon as I started driving a day or two it felt like I needed an oil change! The vibration felt through the gas pedal and floor was very noticeably worse than before, which usually tells me an oil change is due. Then with fresh oil it smooths out. This was the reverse. I don't get it. This has never happened before in any car I've had. However the oil consumption seems to be better. No loss in almost 500 miles so far. But then the 2-3 ounces of Auto-Rx oil treatment I added might have something to do with it.
My only concern with 15w base oil is it being pretty thick for cold starts. Only way I could keep my 285K mile 1FZ from knocking during startup on a camping trip to colorado with 40* nights was by pulling the coil wires to prime the system before the real start. I now run a 5w-40 synthetic diesel oil and the engine seems to love it. Quite a bit more expensive though.
All done! Of all the vehicles I've ever owned, this is the FIRST time I've ever changed my own oil...
I cannot believe how easy that was. I've gotta thank @NLXTACY for his awesome idiotproof thread on how to change your oil, even though I didn't opt for the valve and 90 degree mount this time around.
Decided to go with the Rotella T6 5w40 full synthetic. Cheers!
Good work.. and as usual, thanks to NLXTACY for the writeup.
Just a note.. While I fully understand I am potentially opening a can of worms here, I wanted to point out that with a high-quality synthetic such as what you chose, you can comfortably extend your oil change interval to save some cash, time, and waste fluids.
As to how much.. beyond used oil analysis to find out and dial in what works for YOUR engine/oil, it is very much open to debate. www.bobistheoilguy.com has more info than you could possibly hope to need on the subject.. but be warned.. you can spend DAYS on that site and be so overwhelmed with info you won't actually be in a better place to make a decision.
