- Thread starter
- #21
Search, you heathens!
... What temp would cause folks to worry about viscosity using 15w40?
You beat me to it.I fortify my Rotella with a can of Ro*tel. It makes the exhaust smell better.
Looking at the "for everyone else but USA" oil selection chart for the 1FZ, 15w is good for 14F starts.
AU viscosity chart
1FZFE motor
20w50 oil- -7C deg to 38C plus ; 19F to 100F plus
15w40 oil -10C deg to 38C plus; 14F to 100F plus
10w30 oil -18C to 38C deg; 0F to 100F
5w30 oil -30C to 8C deg; -22F to 46F
A good 1FZ should never have a rod knock, have you had an oil test done, if so, how do the metals look? When I got mine, had 0W-30 and a large filter and a pretty good timing chain rattle at cold start, switching to Mobil One 15W-50 and a small filter solved it.
0w oils may move up to the top of the engine quicker in cold weather, but it provides a thinner coating of oil on bearing surfaces, so kind of a toss up?
Tell me more about the adapter you speak of! I have two cruisers and would love to make the changes easier.Been runing the Shell Rotella, next you need to add the 90 degree adaptor for the oil filter and you will enjoy your oil changes even more...
AU viscosity chart
1FZFE motor
The classic problem is too thick when cold, you can get the knock @bloc mentions or the rattle @Tools R Us mentioned. None of this is specific to the 80, it happens on a lots of motors. ...
... So owners switch to a thinner grade, but too thin and it runs straight out of the oil filter, in particular if the anti drain is weak (or non existent), and on some vehicles (diesel 80 for example) it will run right out of the galleries that lead to the pump, unsure if this affects gas 80's?
