Center Diff Lock
Alright, here is the ultimate newbie question -- Where is the indicator located on the cluster to show the center diff is engaged. Picture would be cool.
Just played with it more during a break and I can hear what I beleive is the module in the kick panel switching but still nothing.
Glen
CDL icon location
Left side of the cluster, to the right of the ABS icon
Here is a picture of the cluster from my '97 LX450 with the icon showing. 96r50 was exactly right that before my edit the previous picture indicated the wrong location :whoops:
So if the ABS light and the CDL light do not come on when in 4L, how would one tell if the center diff is locked during driving? Should it make a slight noise after shifting into 4L? Sorry, I am one without f/r lockers and I dont know if I would recognize the "locking".
cheers
I think it's a little bit to the right of there. I only say that because it's an orange light, not red.
We have a WINNER!! :D
I got curious, decided to stop being lazy, and went out and snapped a picture from my '97 LX - Replaced original pic with one that actually shows the icon
:cheers:
Now that I think about it, I think the red one was the A/T oil temp light. FYI, that light and the Low Engine Oil light both come on if the black-red wire isn't plugged into your starter when the truck is running. Don't ask how I know ;)
Corsair/96r50,
Thanks for the inputs, I have been hashing through the many many many pages on the center diff and have come up with a couple that are very helpful and will give me some spots to troubleshoot tommorow.
What I have compiled is that it is probably a switch (part #84222-12010) located at the 11 o'clock position on the transfer case. It is a simple pressur switch that sometimes gets stuck or corroded but your computer looks for this signal through the "Pin-7" to allow your front and rear lockers to engage.
Will keep you updated as to the progress. On a good note, I spoke to the dealership that did the buyers inspection and they are seeming to be stnad up guys because they said that they would look at it for free and if I decide to have them do the work they will give me the parts at cost and do a little something on the labor. This all because they just recently inspected the truck and did not find the problem during that inspection.
Glen
slinger5150,
I had the same problem. Turns out it was the indicator switch (84222-12010, cost around $45-$50)
Corsair/96r50,
Glen
Sounds like you and gotmud came to the same conclusion :D Hopefully it solves your problem!
You have a pretty nice dealership. :cheers:
Yeah, he is one of the ones I read on listing the part number -- didn't even realize it was in this post. I have been reading way to many to remember who said what or wher eit came from.
Actullay the most pertinent and in-depth I read was by Raventai, he detalis pretty well on the elimination process for vehicles with the symptoms I have.
Glen
Update -- CDL/Low Range/No Locker Actuation
After troubleshooting this problem in my spare time I finally took the dealer up on the offer to check it out. To my dismay it was not the switch on top of the transfer case which I had problem solved as of last posting. I showed them everything I did/checked, thinking this would cut their troubleshooting time down, and they determined that the transmission relay block (89531-60010) was the problem.
This is one of the modules that is behind the driver's kick panel, and they say that when the buyer's inspection was done it worked but now it doesn't so they are cutting me a good deal on the labor for install. So after all this, a $140 part will solve this dilema!!!
Glen
:cheers: and thanks for reporting back! Always good to see the actual solutions to problems like this.
-Spike
before you spend any $$$ was the cdl and abs light turning in when you purchased the truck? I had the sane problem. When i first boght the truck I only tried placing the t-case in 4-lo a couple of times and the light turned on when engaged. Then a few weeks later it quite coming on. Turned out the cdl motor was land-locked and a few encouraging blows with a hammer seemed to free it up. It has been working fine since, and i have made it a habbit to engage the t-case at least once a week. Check to see it you hear a clicking sound coming from the driver side kick panel when you shif into 4-lo. if so your relay is probably working.
just my 2cents:cool:
Rmartinez,
Thanks for the input, I did all the troubleshooting and had originally determined that it was the switch at the 11 o'clock position on the transfer case. I finally got it out and tested it and it worked. THe dealership did the buyer's inpsection and agreed to check it out for me since the blessed it in the first place.
After I showed them what I did they then proceeded to varify my findings and discounted that the actuator in the relay box was engaging. I could hear the clicking only when moving the lever from Lo to High but not vice versa.
I will go with their conclusion and if it is wrong then they will be determining the cause for free becuase this is their diagnosis not mine.
Glen
Update
Alright, I know it has been a while since the last post but I just got time to perform the work (between job, family and other commitments).
I installed the relay box (the one that you would perform the Pin 7 mod on) and it did not change a thing.
Out of frustration I started screwing with the shifter (H to L), maybe pulled it 10 - 15 times but I finally got the center to lock in.
I am assuming this but there is still no dash lights indicating this fact. I took the truck out to drive it and verify that the center locked, it definitely feels like the center is locked (engine seem to run in a different rpm band, truck acts like center is locked, etc.).
So now since the center is locking but not showing indication on the dash, could it have been a fluke and the actuator gave the proper continuity when out then somehow isn't working when installed? Also, while doing research I have noticed a couple references to the J4 actuator, what does this one do?
The FSM shows how to check for the continuity to the ECU harness, my question is where is the ECU located? Is it the silver one that is stacked over the pin 7 mod relay in the DS kickpanel?
Hope this makes sense, currently I am fighting off strep-throat and a slight fever all the while trying to get the truck off-road worthy.
Glen
I followed these posts pretty much to the "T":
https://forum.ih8mud.com/80-series-tech/20182-center-difflock-connector-corrodes.html
https://forum.ih8mud.com/80-series-tech/29474-help-please-cdl-still-not-working.html#post338870
Maybe I need to start over and follow the "Which center difflock connector corrodes??" post.
Fixed --- Kinda
I ended up buying a new switch from the dealer. Replaced the switch and that solved the problem.
I determined it was possibly the switch being intermittant becuase I could get the switch to work while un-installed but nothing when installed. I took a suggestion from a previous post (that I had discounted because the swicth worked while out) and jumped the terminals in the connector. This led me to believe the switch was "acting up".
Now the center diff will lock but I can only get the front diff to lock, the rear just blinks. I guess I will have to look at this next weekend.
Glen
Currently, the most frustrating part of this whole event is that the switch was one of the first items I looked at. When it worked out of the case I discounted it and moved on.
The dealership even diagnosed the relay as the problem, so after $140 for it I find that I could have fixed the problem weeks ago and for a fraction of the cost.
Glen
**Note: the system and the troubleshooting are actually pretty straight forward it was just lack of attention to detail and experience with the system. I could honestly say that even though this is frustrating it has been a very good learning experience with getting to know this portion of the LC.
Where is the CDL motor located on the transfer case?
Crawl under the truck and it is just behind the location where you would see the sensor/switch at the 11 o'clock position. If you have a buddy that can assist you, have them in the cab and you under the truck. They can turn the key to the on position --- but not starting the truck, while you check the motor functioning. You should hear the motor cycle when the transfer case is shifted into low (ensure buddy has foot on brake and emergancy brake engaged). This is assuming your cdl is working. If your cdl is not working you can pull the switch at the 11 o'clock position and test it manually. This should result in the cdl engaging and both the cdl and abs lights coming on in the cluster.
Glen
Where is the relay/ (transmission relay block) , located behind the drivers kick? (Which relay)? I don't hear any clicking and I know the center diff is not engaging! HELP
A pic would be nice:)
This is on a `93 if it matters.
P.S. From my diagnosis, it appears that the indicator switch on the transfer case has nothing to do with whether or not the CDL motor will operate properly or not. It simply lets you know that the system is engaged (no f/r lockers). Please correct me if I am wrong.
