Center Diff Lock
Nevermind, I found it lurking behind the ECU. It says "TRANSMISSION RELAY" on it. Definately no clicking when shifting into low. If the CDL motor is froze up could this keep it from "clicking", or does popular opinion say that the relay is bad?
I'm in similar pain here except the CDL dash button does not operate the "Trens relay" but selecting Low range does operate the "Trans relay" but no matter what I do I still can't get the CDL to disengage. I'm trying to sell my 1990 80 series at the moment and this has put a stop on prospective buyers.
Hoping to hear of a simple problem rather than the actuat motor needing replacement.
Im also getting a prominent clicking sound with steering in full lock (off the bitumen) when CDL is engaged.
Success in Cleaning Transfer Indicator Switch #84222-12010 !!!
Hi, I also had a problem with my transfer indicator switch. My dealership wanted $90 for the part and about 1 week to get it. I had success with just cleaning the switch instead of having to buy a new. Just finished a write-up on it in case anyone's interested: Transfer Indicator Switch Problem with 4WD Toyota/Lexus Center Differential Lock
Thanks,
Clifford A.
OK. I am not the only one. We have had our 97 FZJ80 for many years now. It is the wife's daily driver and has not been taken off road much (which is starting to change). We bought this used. There is no CDL switch and I have not verified if someone did the 7-pin mod without putting in a CDL.
The center diff light does not illuminate when the vehicle is started. ABS does as do the front and rear factory diff lights.
Today, I tried locking the front and rear factory lockers in 4L. Only flashing lights. No locking. Started reading all the associated threads on here. Come to realize if the center is not locking in 4L (as the light does not illuminate), the front and rear diffs will not lock due to center not locking. I do not hear any ticking from beneath the passenger kick panel when in 4L. Sounds like some of you have resolved this by replacing the transfer indicator switch. I am going to pull that right now to see if it tests out OK (using Clifford's nice write-up).
Did you do this on a gravel/loose surface and turn while driving slowly? Driving in a straight line may not allow the lockers to lock - you need a difference in rotation right to left to allow the lockers to lock (hence turning in a circle). Otherwise, they sit there and blink at you... (don't ask me how I know that).
Read post #8 here for a much better explanation:
https://forum.ih8mud.com/80-series-tech/56765-factory-locters-cleanning.html
If the CDL switch is intermittent or not working - it is highly likely that the internal contacts have glazed over due to the very low current that goes through the switch. It is being used as a sensor.
Anyhow, I FIXED mine a few years ago and it has been 100% solid since - cheaper than buying a new one.
This link -> CDL Sensor/Switch documents the process I went through. Running a bit of current through the switch to 'clean' the contacts worked a treat and the CDL switch has never given me problems since that time.
cheers,
george.
Yep, it was on a wet grassy/muddy field. No luck until I read Clifford's post. I took the transfer indicator switch and checked it. It appeared to be shot. Aggressively worked the plunger a few dozen times (with one or two good taps for good measure). She started reading open and closed properly.
I put her back in and took the Cruiser out to the field. Well guess what? That fixed her right up. The center diff would intermittently lock and unlock. I worked the Hi-Low shifter a few dozen times and she stayed locked. Drove around the muddy field for a while, then tried the front and rear factory lockers. They worked the first time.
I cannot tell you how excited I am. I have been lurking for some time, and am always amazed at the level of knowledge around here. Thanks to everyone for their informative posts.
