CB antenna on a 40...
Bozeman, MT
Howdy-
As some of you know I am building up a tire carrier for my 40. I want to attach a CB antenna to the tire carrier (swing out) hoop.
I am unsure if the antenna needs to extend above the roof line to have a proper signal, does it need to?
I am thinking of mounting the antenna here with a quick disconnect to clear my garage. 3 foot firestick FWIW.
I searched the outfitting section and turned up nada.
Thanks in advance-
Rezarf <><
Yes. Your antenna does need to extend past the roofline for a proper signal. This is not to say it won't work, but in order to get the swr correct for a cb it must be up in the air. Is the antenna your planning on using tunable? This will make a big difference in how well it works as well. Good luck!
FWIW, also having it extend above the roof line helps get you closer to having the tip 8' off the ground so that you can tie a red flag on it and wheel in some desert areas and meet their requirments of having a visible flag on a whip at 8'.
Unless you have some incredible coax cable, wont it ultimately get ruined by the movement caused by the carrier opening and closing?
I am building my carrier too and was planning on putting the antenna on the bumper part instead of the swing arms.
By the time the coaxial wears out you will want to be re-working the connections anyway.
my cb antenna does not extend bove my roof line, easier to get caught in trees and branches, have had no probs with signal. but im not trying to reach people cross country, just on the trail
If you mount the antenna to the tire rack, as shown, you will lose some forward signal and also as mentioned may have a difficult time getting a “match” between the radio and antenna. Try getting a field strength meter to tune your antenna with, and just tune for maximum output. Chances are the SWR will be slightly high, but as long as your radio is happy with it and you’re happy with the location of the antenna, try it. Some radios could blow the finals if the SWR is too high, and your radio doesn’t automatically cut back power. If your radio doesn’t like the SWR, then worry about relocating the antenna to a different spot or putting it higher. Antennas like to be above any metal to work well, what you will have is a compromise and it should work OK for trail and local group use.
For the short run of coax on your truck, any good quality coax will work. Stay away from cheap stuff you can get at Radio Shack, most of it does not have good shielding and will allow noise to get onto the radio signal. Get something good like Belden, even the Belden 9913.
If you mount it on the tire rack, put a ground strap from the tire rack to the frame of the truck. Antennas need a good "ground plane" to work correctly. The swivel for the tire rack will not make a good ground connection. If you have a VOM or millimeter, check from the base of your antenna to the frame of your truck, it should be zero OHM’s. Crimp AND solder lug connectors for the ground strap. And make sure the radio itself has a ground strap to a solid ground that goes to the frame. Ground, ground, ground. There is no substitute for good grounds with radios.
Jerry D.
Jerry was very helpful when I was setting up my antenna mount. I followed his suggestions and enjoy a strong signal on my cb. I mounted my antenna on the tire carrier, but with a separate ground wire and all is well.
To stop the banging of the antenna against the hardtop rail, rather than a tennis ball, I used a piece of 1.5 inch backing rod painted black. It's that stuff shoved into cracks in new buildings to fill the cracks. Like solid foam tubing.
I made a mount that bolted up to the four holes on the body where the old spare tire mount was.
Jerry D.
All good advice, except I would disagree with the crimp and solder statement. A proper crimp connection will not need solder. Soldering stranded wire eliminates its ability to flex, which is why we use stranded wire in the first place. If you are using one of the newer organic fluxes any that wicks into stranded wire will decrease the life of the connection since it cannot be removed and unactivated flux is corrsive.
If you must solder a crimp connection use rosin flux and add a strain relief an inch or so from the connection to eliminate movment near the solder joint.
Thanks for all the replies everyone.
I am really only using the CB for trail and small group trips to the trailhead. It sounds like this is an okay spot then.
I plan on using a quick disconnect to get it into my garage and be able to install it or remove it when on a trail.
The ground strap is a great idea, I have had that advice from several sources now.
Is there any difference with a long say 5' antenna and mounting my 3' antenna higher? Will one out perform the other? I can mount a 5 footer on the "bumper" section, but I was hoping to save 20 bucks since I already have a 3 footer.
Thanks again!
Rezarf <><
A longer antenna properly made for CB will almost always outperform the shorter one. But now you want to mount the longer one lower, on the bumper, and this will put it directly behind the tub and top. It defeats the purpose of a longer antenna. Stick with the 3’ antenna you have, mount it on the tire carrier and use the quick disconnect. You want to have communications on the trail, not “shoot skip”.
As for the solder making a connection ridged, RUSTY_TLC is correct. Making a “proper” crimp connection is the key if you do not solder. If you secure the lug correctly and allow some flex in the ground strap, there should be little to no movement at the lug. Please read that I’m saying “ground strap” not ground wire. Don’t use a piece of #18 wire for a ground connection. Use braided flat strap for the ground. If you don’t have any, then find a length of old coax and strip off the insulations and take the shielding mesh off and use it for ground strap.
Jerry D.
Many parts stores offer braided battery ground cables... could be an easy source for those that don't have other sources.
Cut the batt terminal off, get a heavy (thick) metal ring terminal and crimp it in there good... I just put mine in a shop press to crimp it flat (like the cable). You _might_ be able to use a bench vise for this, too.
HTH. -Ed '70FJ40
if your using it trailuse get a short one and radio shack cables and pay less than 50 for everything and be done
i have a 5' firestick and it does better than anything i have ever seen. my freind has a 3 footer and his range is a little less but not noticeably. the one thing about mounting on the carrier is that you have to have a spring on it so it doesnt break, its going to flex backwards and forwards. you have to make sure that when it goes back it wont hit the tire and bend. firesticks do not bend at all thats why they have springs. i have a 5' firestick i would trade for your 3' but i dont know how to ship it. if you are worried about hitting it on stuff ten go wiht 3 foot. for how you use it you wont notcie the difference. wiht my 5 foot i can talk to people about 15-20 miles away depending on weather and my freinds 3 footer will do 5-10 miles away depending so its nota big deal for off road.
my $.02
-miles
Thanks again for the replies-
Miles, are you comparing "apples to apples" same radio, power output, swr readings?
If that is the case I may go with the 5 footer intsead.
Am I right in saying that if I mount my antenna on the stationary part of my carrier (not the swing arm) I will have a more consistant SWR reading? For my use, is this a big deal? I would like to do it right the first time, and since I am still fabbing everthing up I have a "blank slate" to get it done right the first time.
Thanks again, I am learning a lot from this thread.
Rezarf <><
If your use is just for the trail may I suggest you get a truck stop or radio shack magnetic mount. Then when you need it stick the sucker right in the middle of your hood. It just plain and simple and no fuss. Plus you will get great reception due to its location.
ALF
