Caster Bearing Install
Westminster, CO
Question for those that have installed these: are they supposed to stick up this high? I know they come with an extra shim, but this seems way higher than the races I removed.
what kit did you go with?
Fair enough, that I made sure of. Bastards were tight, I ended up freezing the races and heating the ball a bit.
So long as it is sated, your golden. While the race is a bit taller, the bearing shoulder us slightly less than the standard 20003 bearing.
All that available adjustment and no neg camber dialled in ?
we use 20 minutes for an every day style driver on 35s, I run .45 deg neg camber on my own trucks.
[edited ]
Pretty sure they must be 0.45 degrees negative camber, because 45 degree would be hell on tires ;).
I bought the same SPC bearings from Slee, I am going to go ahead and run 1 full degree negative.
Depending on the tyre, and what toe you run, you may find that the vehicle will wander more on the hwy if you go to far, and can be more prone to lock a front wheel under hard braking.
Ideally more caster for the kingpin inclination angle when turning becomes more important than more neg camber.
And you have to go to a heavier rear sway bar to get the rear to keep up, and prevent the 80 roll steer, once you get the car pointy in the front.
or 2wd conversion for a turbo petrol 80, for 2 burning, and 2 turning :steer::smokin:
We use 32mm for the heavy version.
We make them longer in the leg to the front bracket for lift as well in the rear and heavy duty links to go with them.
We only change the front on van towing road models, as they tend to make understeer, especially in an awd model, but they will help with some roll control with those shocks too.
We dont have any success with reliability with that particular brand of bushes over here either, be interested to see how they go in yours.
I couldn't even find a 32mm rear. I found a 32mm front. I am hoping since the total suspension movement on this truck will be limited that the bushings will last, but I guess we will just have to see. What other company do you use that has sway bars and bushings? It's likely not one we can get here in the US. Or if it is they don't advertise any Land Cruiser parts for the US market because I spent quite a while searching and even then it took me 6 almost 7 months just to get these sway bars.
Should of PMed me LOL.
We have ours made for us [have a 38mm rear too]
Next problem is the tread block sidewall wear LOL
Super Pro stuff we have used for a long time, firmer duro for control arms front and 100 LCAs etc too, we have had made to firm up handling, offset front arm bushes, and some new arms with a polymer material coming for more articulation from the bush, more easily.
These bushes were set 2 between services.
