Carrier pin woes...
Nashville
Hi all,
A few weeks ago, I went to install an Aussie locker in the rear of the 40, and when I went to take the 12 mm bolt out that holds the carrier pin in place, only 1/2 of the bolt came out (or what I thought was about 1/2). Instead of trying an easy out or something to that effect, I just buttoned it back up. I called an old school garage that is near my house to see if they could get the bolt out, and they said they would try, but after looking at it, he said that he would destroy the chunk trying to get it out.
He also said that my pinion had a lot of play and I would need a new pinion bearing.
Anyone have any suggestions or experience with a broken bolt in this location?
Do I just need to find a set of 4.11 gears, swap in the aussie locker, then replace my entire chunk?
Not good timing, as we have a large trail ride coming in the next few weeks...
thanks in advance,
Joel
The pin is just held in with tension. It's generally fairly easy to get out. If the chunk needs to be rebuilt anyway, it's a piece of cake to get out.
You can also use a dremel or air die grinder to notch the cross shaft to drive the pin out. I had to do that to a ARB carrier I rebuilt.
Without pictures it's hard to get a good idea. The bolt you are talking about only has a few threads. The end of it is a pin. I have seen many of them break whe the spider gears give up. The cross shaft gets sloppy and breaks the pin. I've not seen the threaded part break. Are you sure that is what happened?
Been there done that. It sucks! I tapped the carrier with a hammer until the pieces vibrated out one by one.
Keep tapping. I also used a tiny screwdriver to work the pieces loose. I even tried to magnetize wire to see if the pieces would stick to it. The whole process took hours. Not sure what method worked best but it all finally came out.
The reason my pin broke is that a PO put one of the spiders in without the thrust washer. I believe the slop must have been too much for the pin. I had to get a new thrust washer to replace the one that was MIA.
I'm going to take the third out, put it on the bench and see what I can see tomorrow. Thx fellas!
Just to let you know, unless you have a non-USA full-float rear axle, you will not get that third out of the axle housing until you get that cross shaft out to remove the c-clips retaining the axle shafts into the diff.
:beer:
^^Yep, what @Poser said.
:beer:
Holy carrier pin, batman! You're right, a tapping I will go, LOL
If you're good with a welder , I've fused a few of those pins out with a 1/16" welding rod - just jam against the pin end with low amperage setting (not enough to strike a full arc) and use the welding rod to pull it out . Sucks doing it under the truck , I'd advise banging it first though unless you have a very confident welder . If you screw up and start an arc , that pin is never coming out and harder than ever .
Sarge
Sarge
Wow that is a great idea. I'm gonna use that someday for certain.
Be careful , some tig welders don't like that direct feedback and will snap off the current at the wrong time . Practice by dropping a piece of rod down inside a tube , set the welder low enough for a 7018 or 6010 to stick easily and not start an arc - just jam it into the center of the rod as best you can . I let it cook for a second to two seconds , then snap the electrode holder off the rod , let it cool and remove ....
Sarge
So to clarify, the threads on the 12 mm bolt are nearest to the top (nut end) not the bottom, correct? If that's the case, I should be able to tap it out, since the bottom section has no threads in this photo...
