This group buy has been canceled due to lack of interest.
Talk about these replacement valve stems has been making its way around ever since their successful crowd funded launch. Finally they are available to everyone and I've been able to negotiate a group buy discount from them for our members here. There will be a coinciding group buy notice placed on the private Mo4wd web forum that will help get the committed buys requirement fulfilled.
I already have a pair of the emergency valves in the tool bag of each of our trucks for emergencies and am grateful for the extra security that they offer us if we ever get into a jam.
So what is a "Colby Valve" and why would I want to order some?
The patent pending Colby Valve is the only tool-free solution for replacing tire valve stems from the OUTSIDE OF THE WHEEL, on-location, in 5 minutes or less. No tire removal. No special tools. No problems.
Colby Valve's patent pending design features a custom valve, machined from solid 360 brass bar stock. The valve's wedge design works in concert with our high durometer synthetic rubber seal to expand inside the wheel and create an airtight seal.
Colby Valve is a cheap insurance policy that every farmer, off-road enthusiast and heavy equipment operator should have. Oh, and it's made right here in the USA.
How do I install it?
When your valve stem fails, simply pull it out or push it into the tire cavity. Take the Colby Valve and insert it into the valve stem hole until the lip of the black seal sits flush. Maintain pressure while tightening until it stops, and you're done.
The Colby Valve will create a super strong, airtight seal that can then be inflated with any Schrader style pump, including CO2 inflators.
Not only can you get back to civilization, you can keep going and enjoy your adventure or finish your work. The Colby Valve is 20X stronger than the common valve stem, so you'll be good to go. The wing nut on the emergency valve is offered in black, red, and orange.
Do you have a set of wheels that you'd like the security of Colby Valve as a permanent option? They offer those as well.
The 20% discount will be subtracted from the listed prices on the Colby Valve website.
- Fits standard .453 wheel openings (everything from bicycles to trucks)
- Installs from the outside of the wheel
- Under 5 minute installation
- NO TOOLS required
- 20X stronger than standard valves
- Available in 2-Packs
- Black, Red and Orange spacers available
- Quality 360 brass components
- Made in the USA
- There needs to be 25 participants to qualify for the Group Buy discount.
- Once we reach 25 committed buyers, the discount code will be presented to us.
- The code will give 20% off all of the Valve packs: Emergency 2-Pack, Permanent 4-Pack. Permanent single add-on.
- The code will remain active for 2 weeks.
- The discount code can be used as many times, and for as many valve products on their website as you all want. It will not discount the apparel.
- Shipping costs are calculated at checkout. Most orders will ship First Class for $4.99 domestically. Domestic Priority Mail is available for around $8 for almost any size order. International options are available.
- Orders ship out within 48 hours during the week, with many shipping out the same-day.
