Can you run catless
So im gonna take off the air tubes and put the 02's in the bungs that the tubes connect too. Ive seen it done, and after 10k miles and a passed emissions test i know that it works well.
Question is, will it run without the cats, does it need the back pressure, or will it be ok without them. Im registered in Tn so i have no emissions or inspection to worry about. Both of my cats and the muffler leak (factory stuff) and i was only gonna delete the cats to clean up the underside of the truck (less stuff to hit off road). Im not looking for a power gain. I know my 4bangers have to have the cats to run right. I was just wondering if anybody here had run a FZ motor catless and if so how it worked out.
Thanks in advance,
Will
No. Why would i ask zuk questions in the 80 section. The zuk is so custom its far beyond questions anyways.
I have 2 FZJ80s. One im gonna wheel/tow with and the other is a dd.
With that said, does anyone have any opinions, ideas, personal experience runnin catless on a FZJ80.
Thanks in advance,
Will
Since it's not OBDII, you should only have two O2's, both pre-cat.
IOW, you shouldn't have a problem.
Im not neccesarily worried about the 02's. Theyre gonna go into the air rail bungs on the exhaust manifold. Im just curious if the motor needs the backpressure they can create. Seems like it should be fine.
Thanks in advance,
Will
You should be fine. I ditched my cats 40K ago on my '94 and it has run fine ever since.
You didn't have any 80's info in your sig or the post at the time i responded that is why i asked. As mentioned above the 93/94 models only have one o2 senser before the cat. It wont hurt or help preformance removing them, so as long as your state doesn't require them for annual inspection, like mine does. Overall they do help clean the air a little.
Thanks, I greatly appreciate the help.
Will
I ditched the entire system from the cat back.
I moved the sensors into the PAIR bungs and put 2 cherry bombs inline with the outlet infront of the rear tire. I was concerned with zero back preasure so I put a small deflector after each cherry bomb. Been running like a charm and the sensors have survived/functioned so far with no CEL.
https://forum.ih8mud.com/80-series-tech/277929-cat-may-back-not.html
It is a bit loud on full throttle but I drive like an old lady most of the time.
I think you will be just fine.
cats
does anyone make a test pipe to replace the cats?
marlin- nice exhaust setup, i thought i read in your post you were planning to put slidders on at some point.
-have you put sliders on and what did you do with your exhaust then?:)
No sliders yet, and still no tickets for disturbing the peace :lol:
Since you have no emissions regulations, I think it is a good idea. Those cats are one of the lowest things on the main belly of the rig and are pretty vulnerable. I check mine everytime I go out because I always worry about smacking them on a rock and they aren't the cheapest thing to fix. Another plus would be that you wouldn't have to worry so much about starting a fire. Here in Nevada we have fires all the time from offroad vehicles igniting the cheat grass. The only thing to watch for would be traveling into an area with emissions regulations they will get you. (I know, it was a 400$ lesson):doh:
really, they spent time looking under your 80 and found you didn't have cats, was the stop due to a lound exhaust or was it an unrelated stop(ie: speeding)
I have the cats off of my 80 and left the O2 sensors where they originally was. I would get the code for bad cat occasionally before removing them. And only once got it after but I have the code reader and clearer installed in my dash so its easy to clear on the fly.
With the stock mufflers it does get a little bit more noise from the tail pipe can hear it from the inside. the passenger floor temps went down %1000.
Now when I buy fuel from the guy on the side of the road out of old 1 liter coke bottles I dont have to worry about what its is and if its bad for the cats.
YouTube - Cambodia and laos by Toyota Land CruiserYouTube - Cambodia and laos by Toyota Land Cruiser
i just had a set of magnaflow 94004's installed on my truck and they seem to have done the trick. They were only 115.00 shipped from JC Whitney. Not legal in California though...
It wasn't the 80 that got me the ticket. My 1980 toyota pickup had a cherry bomb on it and that was what gave me away. It actually came factory without cats, and I would have opened the hood and shown the decal that specifically said that, but I had removed all other emissions compliance equipment and didn't feel it necessary to possibly make the situation worse. It is funny now but I sure was mad then.
