camcruisers ram assist write up
looks good cam, you need this guy to lean into those turns so you don't roll.
Noah
Cam, you have been busy. It's looking good. Did everything go smoothly tonight? I will plan on seeing you Wed. for more Saginaw fun.
Dave
i rest on the eigth day man,
get r done
wednesday work for me
noah,
how long you been holding on to that pic????
okay so where i left i i got the parts layed out that i need to finish putting in
i also finished the welding and cleaned the bracket up and painted
i then installed the ported box and the tie rod.
next to go in was the ram and the hoses
while i was at it i put on some diff armor too
and some more shots of the ram to give a bette idea how i mounted it.
i love wide angle cameras,
whats left i need to route the lines attach them to the box and mount the new pump.
its turned out pretty good
I tighten the knuckles every morning before I wheel, no problems as of yet. Ben is the only one in our crew that has sheared knuckle studs (arp) and he is running 44's, he is pretty sure the reason it happened is because after installing arps he neglected to tighten his knuckles regularly.
That's encouraging, I may have to get hydro assist now:cheers:
got the lines ran and tied up get to test it later today i hope
all the hard work is done, im will be installing a bigger cooler for the fluid and then its test time
