Not sure if it will fit the Columbus but worked well with my Tepui. The rack is 53" wide and 63" long.Is this rack big enough for a Columbus pop up tent?
I think I'll take it. Any pics of it?Not sure if it will fit the Columbus but worked well with my Tepui. The rack is 53" wide and 63" long.
Cleaning out the garage. PM for details:
1. 1982 FJ40 4 speed.
2. FZJ80 rear e-locker.
3. OEM 4.11 gears great for a 40 or 60 series swap if you have the 3.70s
4. 100 series ARB rear bumper with swing out tire carrier.
5. 100 series sliders with front fender bars.
6. 100 series front and rear complete 4.30 diffs.
7. 100 series 17" rims. All 5. What some call the Aussie style. Rarest of the 100 series rims.
8. Older 5 gallon (I think) shop vac. Noisy, but works with lots of attachments. (Free!) Gone
9. Coming up: 80 series front and rear axles with open diffs. Front axle has new cvs.
I sent you a pm, but not sure if you received it or not. Is it still available?Cool buddy you can come pick it up whenever.. I knew it would find a good home here in MT! Just ran out to the garage and snapped this pic for ya.. It's an older model where Tim did the 270 degree welds on the plates and it has both front and rear accessory tabs.
That seems like it would suffice. I was reading about those in this thread too. My Trailer Build Plan W/QuestionsHow heavy of axle do you need? Just ordered a 3500 lb dexter for 150.00. Way cheaper than i expected, no brakes on this 1.
PM sent.Still have the locker?
Can't think of the name of the place, just south of belgrade on jackrabbit. the trailer place. Depending on spring length they might have them otherwise tnt springs in belgrade.That seems like it would suffice. I was reading about those in this thread too. My Trailer Build Plan W/Questions
You still have this?Free to a responsible home: Craftsman 3 ton floor jack. Im getting rid of it because it has a leak and loses height while your using it. I believe the replacement cylinder is 40$ but you have to figure out what exact model it is. I was cleaning the model number sticker so I could read it better and the numbers washed off!! So to be very clear: It's NOT super safe but it does go up to 19 3/4" so if you are currently stacking 2x4s on top of your regular size jack then maybe its safer than that. Ideally this jack is a 2 person operation; one person keeps pumping it while the other person puts jackstands under the axle or frame. So its free but I might ask the new owner to sign a waiver acknowledging that its unsafe.
Yes. Sorry, the 275/70 is what I'm curious about.Do you mean a 275/70/16 or 265/75/16? The 275/70 is the stock 80 series size and many tire shops replace them with the more common 265/75.
Anybody have a pair of front doors for an FJ40?
1 piece full steel doors, sorry should've included that1 piece or 2 piece doors?
