Buying, Selling & Trading
I do. PM me.
I’ll throw this out there but I’m looking for a rusted out/beat down FJ62 to use one my FJ40 3.0 build.
I’m really after a “2FE” conversion or 3FE fuel injection motor, the split case and 60 axles.
If you know, hear or see one let me know!
I've got both a 2FE and a 3FE up in Helena. what splitcase are you after? 4 different versions. if you want 62 axles instead of 60, I've got either of those also.
Paul
Paul
What would you charge for a 60 axle? Hoping to SAS my fiance's 86 4runner this year or next. 60 axles match the rear ifs width perfectly
Paul
Wow Paul, that’s awesome.
Either of the two engines would work. I’d need the harness and ECU, I’d like I go from the 2F3/3FE to a H55 then use whatever split case is needed from there.
Selling my almost new Frontrunner Slimline II Rack. This will work for either an 80 or a 60 with the feet that come with it. Spacers or different foot mounts will probably make it work with any other vehicle. Price includes the rack (53"x84") Low profile feet set (6), spacers, 3 extra slats with end caps, roof top tent brackets and mounts for an Autohome, front led bar brackets, additional light brackets, and a foxwing or batwing bracket set. Total new with all parts is over $1,700. This set-up was only used for the last few months, and is in like new condition. I'm just going a different route and really don't need a rack. I'll post up some pics when I pull it off my truck. I'm waiting for my new set-up to arrive.
Selling for $975. Local pick-up or you pay shipping. Thanks!!
Looking for some factory FRONT coils from an 80 series. Looking for either 7, 7.5 or 8 wraps to put in the back of my 4runner. If possible id like to test fit them to see how the lift compares to my current coils. My current coils are a bit too soft and are sagging a bit I think as I have been hitting my bump stops more than I wish I was.
PM me on the coils.
Looking for a good rear 97 rear 80 series driveshaft core. Thanks!
I have front seats for a FJ60 that are in alright condition with SOR seat covers. The drivers side seat cover is worn through on one side but otherwise are in good condition, Im asking $100 for the pair. I also have a carb fan and a rear hatch that has some rust and a dent. Message me if you are interested.
Looking for a rear 80 series driveshaft. My rear one has worn splines if anyone has one lying around that would make a good core. Thanks!
3 speed transmission with t-case. includes a ramsey pto. Out of a 69 fj40, also includes all linkage. make offer, tired of tripping over it Gone, went to get another 40 back on the trail
Toyota 70/60 drums and rotors
Aftermarket 70/60 drums haven't been on long from the looks of it . Also have a brand new set of pads for the drum that go with it .
There all FREE if you want them otherwise there headed to the scrap.
Set of used Wildcat Radial A/T tires 265/75/16 with 6/32. $100. Great for anyone needing some on a budget.
Hey Bozeman guys. I am selling my 85 FJ60. I’m asking $7000. Want to sell it here in the Bozone
I just am not using it after all the work I put into her as I am using my 84 as my go to rig for fishing and hunting. 85’s in pretty damn fine shape. No front window cracks. CooperSST33in tires, very little use. I’ve done a full de-smog including FJ40 Jim C’s recurved dissy rebuild. Installed a saginaw power steering pump. Full AC recharge. I pulled the entire interior as it was in pretty bad shape, well worn. Completely gutted and washed down. Installed reflectix as insulation….no stink and better noise control. Put in the interior from my 82 parts car. New rear carpet. Repainted the dash to match brown color as in my 84 and installed a ‘dash cap’. Super power washed seats, exterior and undercarriage with a ‘real’ high powered power washer that I had. Undercoated the doors interior for better sound control and install kickass front speakers. I do have rears to put in if you want them. Wired up while the carpet was out. The carpet is in about the usual shape for the miles. The usual mileage you see on these rigsis about262,507.Royal purple trans and transfer case oils. I put in a new clutch set and ground the pressure plate. I believe a KN air filter.New brake master cylinder. Wiper blades of course. Buzzer for the headlights if left on. Yup, you can tell I’ve been an Ih8muder for some many years now.
Power booster for brakes or proportioning valve may need replacing as the pedal is not firm as it should be.Sender for the carb fan my be out as it does not come on. You need to raise the hood for awhile after driving it if you drive it. I have not looked into it. Muffler is ok but you may not think so, I do. Paint is ok, could use a good wax job and there is just a little rust damage…..say inch and a half over both rear wheel wells. I got it...stopped with a good rust preventative. Usual drivers seat issue. Need to install rear hatch lock, I have it.
All receipts and notes I’ve made. I’ve also got the carb, front axle member and a few other goodies I will give up as well from my 82.
I am looking for a mid to late nineties rig….maybe a200X, just stepping up a grade. This will be a great rig to have if you get out there and go for it, been there done that. John Bauser had one for me before he headed out to Africa, damn it.
1st owner had it garaged at all times and second lived up in Boulder. I am 3rd owner.
My internet allotment will be used up by tonight, Monday night, so I will not have iH8mud access until the 18thin you want to send me a PM. Sorry for that, I hate satellite up here in the woods.
I tried to PM you, but was not allowed. I am interested in your '85 60, I would like to see if it is a better starting point than the one I have. Please PM me.
