Bumper spindle cover
Erie, Co
I have a truck with a bump it off road bumper and tire carrier. My wife is using it as a kid hauler so I'm taking the carriers off to help her get in and out of the back more easily. Does anyone know if someone makes a cover for the exposed spindles once the carriers come off? I might have to 3d print some up if necessary but thought I'd give it a shot.
Hit up a trailer supply store because I believe it's just a stub axle. At least, mine looked that way when I put it together.
Yeah if I'm going to go the way of fabbing something simple up I'll probably just 3d print a good fitting cover. Was hoping there was an off the shelf solution for it that I could support but sounds like there isn't. Appreciate the insight.
just get a short section of pvc that just fits over it, and glue a cap on it.
ABS plumbing and a cap!
You could use a tight fit by heating the ABS/plastic tube and slide it over!
Mine is a hub complete with bearings, seal and cap. With no arm welded to it. I made mine but you could call the manufacture of the bumper, I would guess they would sell you one, but PVC would be cheaper.
