mderrick, I cut out a rectangle and flipped it to slightly raise the fill height. I went from 0 degree pinion angle to 6 degree and i wanted to make sure I had enough oil on the pinion bearings. It probably wasn't needed, but I had the housing stripped and on the bench, so it was a good time to do it.
It turned out both my diff's needed master rebuild kits. One of the carriers had spun a main bearing, so I used another carrier. Everything is fresh as can be. My friend from American Axle Quality did the rebuild himself. I am running the 3.70 gearing. I hope that is good for street use...
The Barnes offroad perches have the extra holes for axle placement. I am setting the front forward the extra ~1.5 " and will set the back the same amount back. This should help with tire clearance on the back, as well as making my Drive shaft a little longer and shallower.
I am at a computer now, but most of my posts are I-phone posts, so please excuse the brevity.
Thanks for reading my posts.
It is nice to bolt something to the frame finally. All this cut and turn, plus perches, cleaning, and rebuilding has taken quite a bit of time.
