BudBuilt 200 Series Skid Plates, Sliders, High Clearance Rear Bumper
Frequently Asked Questions
Hey guys, so I've seen a few of the same questions comes in on PMs, and a few single questions, that we thought of, but realized I never mentioned them.
Skid Plates
1) Why no holes along the bottom of the plates? Could help with mud removal, heat, or weight savings?
  • Off-Roading is awesome, and it's not a competition, its a fun thing. But BudBuilt armor is made by guys who are hard core rock crawlers, body damaged guaranteed, 5' bolder hoping, please remove all glass cause it's getting shattered trails. That's NOT to try and be better than someone who doesn't do that, far from it, but this stuff is made by tough wheelers. Skids plates need to be smooth, every hole, every edge, everything other than smooth metal can hang you up on the trail all day. I'm normally an "just my small opinion" guy, but this is just one of those facts. Skid plates have to be smooth to do tough trails. Holes look cool to those who don't wheel hard trails, but the last thing needed on the item that scraps along the earth is holes that greatly add hangup points and weaken the strength (also note that BudBuilt will never etch a logo into armor in an effort to advertise)
  • Heat (see below).
  • Mud removal: holes don't help in real world. Mud is sticky, it needs to be removed by hand, putting a hose up there will not make it leave the top side of a skid plate any more than if hole where in it. Also note that BudBuilt is made by east coast, Tellico wheelers, in my opinion, the hardest trails in the US, imagine the Hammers, but covered in slick gumbo mud. Bud knows a lot about mud.
Does the skid plates keep engine heat in? No
  • I tested the 200 drivetrain heat a lot in California with stock skids. That was with temps across a month of low range, 3 hours trails, in 70 degree weather. then doing the same areas (especially the transmission pan) in texas under 90 degree, 3 hour low range wheeling with BudBuilt skids, the temperatures across the drivetrain were the same. Bud always take heat into consideration, I mean, he was an autocross and rally car engineer for over ten years, but he was the only manufacturer on the FJ cruiser skid plates to retain the factory front differential cooling design, so it's always been a major part of Bud's designs. Back to the 200 skids, the width of the was actually determined from the catalytic converters. Protecting them, but letting them fully release their heat. But also there is the fact that the front stock skid plate design has absolutely no provisions for cooling, the transmission pan does, but testing has show the transmission plate isn't sealing any heat in. Besides, cooling is done by the radiator and auxiliary ATF cooler. Our drive trains aren't air cooled like an old VW beetle.
Why is the front plate 2 pieces?
  • This is a biggie for me. When you wheel, a 3-4 ton Toyota, on pointy things, the surface area of all that weight gets transferred to the weakest part, and that's the frame crossmembers. I've bent every Toyota engine crossmember other than the 200 I've had, because of (and this is where I wanted to learn from Bud) poor armor products having all the right specs, but not distributing load right across the factory parts underneath properly. I have bought a lot of other company skid plates over the years. I've also scrapped all of the other than Bud's skids. Now this, for me, was not on a 200 series, but on the tacoma, FJ/4runner/prado frames, but the theory is the same. It seems like every skid plate out there is a big one piece of plate with a simple tube and washer welded to mate to the frame by bolt. Then there are about 6 of those attachment points across a few feet long by almost 2 foot wide skid. So the whole truck has to be held up by a 6 sq in amount of surface area when coming down on a rock? (mean Taco time, are you kidding me?) The stock plates, just like the stock bumper, is designed to fail before the stuff that really matters under it gets damaged. Protection is there to stop damage, but engineering, makes it to where knowing that eventually something WILL fail, so make it the cheap thing to be damaged first, not the expensive thing. But also, engineering stronger products, makes it to where you need to distribute that impact across the right about (and way) of surface area. That's where Bud, as a formal, experienced, engineer with specialties in material science and failure analysis makes that difference. And, I hate to say this part but in my opinion it's true, a fabricator just doesn't have the background to accomplish the right thing. And the reason I kept going to Bud, regardless of where I have been stationed for the last decade, is because I've lost a lot of money, and had to repair a lot of metal, till I found a guy that didn't just make a strong product, but made a strong product that also protected the very thing that I'm paying money to protect... that costs way more money, the truck itself.
Oh and the next run of skid plates is ready for welding the mounting systems.
So gave a call to Bud's and with four people, we estimated about $75-$80 savings on shipping based off a random zip code in LA. They don't have firm weights yet on the sliders or skids either, but it was estimated with a higher weight just to give an example.
Obviously, the more people jump on, the more savings there'd be. Weren't more people in SoCal interested in skids? ;)
I'm interested. San Diego.
Great! I was talking to someone else and I just used a LA zip code near work to get an estimate, but will probably use my friend's business address in OC. That would make it a little easier for the SD people if they were interested in jumping in.
Obviously, if people have orders already placed but want to save a bit on shipping, it may take a week or two more for everyone's order to be fulfilled. Maybe more if orders weren't placed yet.
So far, I have a friend and I commited to sliders, and I may pull the trigger on the skids too. That would be three pieces so any forum members wanting to join in, let me know. Thanks.
I'm still in for the stage 3 skids, were you able to get an estimate from Bud when these might be available?
I didn't get Bud on the phone but obviously I want to know too.
Ok, thanks, I thought that you were able to speak to him in person when you got the estimated shipping discount. I'm sure that he'll start returning calls once he's able. Will let you know if I get a call from him.
Yeah, I spoke to Jackie for the quotes. I've got to call back tomorrow anyway so I'll see if I can get that answered as well.
should we go ahead and place our orders on Bud's website?
Agreed that calling first is a good idea, and in looking at the website, it does not appear that orders can be placed electronically currently, but maybe it's just my computer.
That's correct. I haven't allowed the website to take orders, purely because it needs to be understood that they are still being produced, and not ready right now to ship.
That said, I'm in the shop today and 2.0 skids just went on. Bud completely redesigned the transfer case skid, and it is just awesome. Even more clearance now! And stronger.
The engine skid (second skid front the front) has an additional set down for more clearance under the front differential. So you guys know, we had two directions we could go with this, make the whole engine plate lower, or only make a set down for the diff. Well doing set downs as to the cost, but it gives more clearance to the rest of the area. Thing the same theory as while you wheel, you try to avoid the rear diff from hitting rocks by taking a line that puts obstacles between the rear diff and shock mounts. Well, if you need every bit of clearance you can get, put the rock to the front passenger side and gain an extra 1/4" of ground clearance. A lot of work for a small return, but that's why I love Bud.
I'm getting skid and material weights and pictures like crazy. Give a call if you want to talk, I got the shop phone on me.
I had a good 40 minute conversation with Rob, and he clarified the improvements that Bud was making to the transfer case skid in order to provide better ground clearance and to achieve additional weight savings. Although these incremental improvements will take some time, it sounds like the final design will be worth the wait. Rob didn't want to make any firm commitments, but did indicate the wait time will most likely be from 4 to 6 weeks. I am still interested in a group shipping scenario if everyone else is still ok with that (@RET2, @Obi Wong Kenobi, @FALKOR8, @tplane2)?
Last night at about 11, another pair of sliders came out of powder. This set was .120 DOM Rock Slider with Kicker, Full Fill plate, Dimple Die Down in semi-gloss (40%).
I just love how far back the 3/8" frame plate goes. The rear lower control arm bracket sits parallel to the second to the last leg! Then because of the 6 leg design, legs can attach much farther to the ends of the main tube. It takes a lot more time and to build a slider with this level of detail, but it's also easy to see why it's hard for the industry to match the strength of a BudBuilt product.
Here is the bottom, but if someone wanted Dimple Die Up, it would look like this. It's a modern take on diamond plate with the edges providing a traction surface.
5/8" grade 8 hardware with 3/8" plates fasteners are in ADDITION to all the M8 bolts that the rest of the industry uses to attach to the frame. It's absolute overkill, but another example of why deflection of these sliders are incredibly minimal, especially when rock bouncing a 7,000 lbs land cruiser.
I'm gonna be in the shop again today, finalizing all the weights (had to call it at midnight) and going to get some pictures of the 2.0 skids.
View attachment 1509407 View attachment 1509408 View attachment 1509409 View attachment 1509410
I REALLY like those sliders. Looks like they don't require drilling? I think I will take a pair in flat black. How far from the bottom edge of the LC do they stick out? I like that they are angled upward for some extra clearance.
Absolutely no drilling, at all. I actually think the flat black looks amazing on a glossy paint job. I think because I like the contrast, but since my truck is Line-X, I think I'll go semi-gloss to have both shinny and matte finishes on my 200.
Apparently a pair in gloss white went out last week for someone with a pearl white 200. Pretty sleek and clean if you think about it.
The outer tube sits 15.5" off the frame (about the same as a Slee slider for reference. The kicker adds 2" to the main tube. So 17.5" off the frame. Now that is strait out distance, like you mentioned, they angle up so they gain about 2.5" of ground clearance over a step slider.
Sweet! I agree the contrast of the flat black would look good on my black cruiser. What is the lead time if I place an order, and how do I place an order? Thanks so much.
Lead time is honestly about 6 weeks out, but might be even longer. Another huge shipment of metal came in yesterday, and we found "Made in India" on a coupe pieces. So that all has to go back, only USA steel comes into this shop. So there adds another week to ensure the right raw material.
You would just need to call the shop and place an "order." But nothing will be charged and you'll still get a call when they are done to make sure you still want them. No commitment at all.
The reason is because there has been a rather overwhelming response for Bud armor, and with even trying to deter orders by stopping quick online purchases, they are still coming in.
Bud has a few more fabricator/welder interviews next week, but he's turned down over 35 guys that got to actually get a chance to build in front of him. He really needs probably two more guys, but if they are not up to standard, then lead times stay where they are at with his current crew.
