The connector that snaps into the IAC on the throttle body shattered when I pulled the TB. Has anyone sourced this or do you have the Toyota Part number? Thanks
Thank youThis is the correct one from ballenger
Ballenger Motorsports - High Performance Electronics
www.bmotorsports.com
Thanks; they have a version of the connector all made up with seals and terminals and a pigtail. Great stuff. ThanksYou'll need the seals too, and if you replace them, new terminals. Both are available from Ballenger. If you can't find what you need on the website, call them. They are very helpful.
What are you working on? This is from the 1996 EWD, available in the resources section.Does anyone happen to have a picture of which pins go in which position on the IAC valve connector? Unfortunately, the old connector completely shattered and now I am unsure of the orientation. Thank you so much.
Kudos to @TomHDoes anyone happen to have a picture of which pins go in which position on the IAC valve connector? Unfortunately, the old connector completely shattered and now I am unsure of the orientation. Thank you so much.
