Brakes again
The Ghetto
I just had new cylinders and shoe replaced on my front FJ40 axle, new shoes on my rear 87 4-Runner axle, new Master Cylinder, used Booster tested from CruiserParts.net. Now i'm getting a call from the shop telling me that the brakes aren't getting the pressure needed when slowing from high speed. They even checked the lines, bled the hell out of them over and over but nothing. What the heck could it be?
Sounds familiar. I'm no pro, but I've been bleeding brakes for 25 years, and I can't get my new brakes to pump up. All my parts are new Toyota OEM, including calipers, MC, cylinders and flex lines. And yes, I bench bled the MC. Twice.
I'm thinking about getting a wrangler. :crybaby:
mdjohnsen said:
I had one. They suck.
I hope the "I'm kidding" was implied.
Reading the other current brake thread:
https://forum.ih8mud.com/showthread.php?t=97488&highlight=adjusting+brakes
I think I may just need to adjust my new cylinders more/better before I can expect the first pump to not go to the floor.
I need a new booster too.
After that I fully expect that I'll need a new brake pedal. That's the only part I haven't replaced. :flipoff2:
I just got off the phone with the brake shop and they said my 87 4-Runner rear end "rolls". Not sure I know what that is. So, I asked. I need some kind of bar to stabilze the rear end. Huh?
Check the booster rod for proper length. The rod that goes into the brake master cylinder and the brake pedal rod that goes into the booster. Those are adjustable.
Are your rear springs kinked in an S pattern? If so it sounds like you need a traction bar and some new rear springs.
Traction bar..
Should not make thatmuch of a difference for braking tho..
Did it suck this bad before?
Sounds like they don't really know what they are doing...
Ok. Just got a detailed explanation on the "rolling". My frickin rear is loose.....HS!!! They said they were bringing it in to the lift when they noticed that the rear end was moving and the U-bolts were loose. That will probably make a ton of difference in alot of things. Anyways, they said they'll tighten everything up but geez...how do I keep this from happening again? Yah, before you all start....i'll keep it tightened down but isn't there something more permanent? FYI...I have an 87 4-Runner rear end.
It has to be really loose to roll. It seems you would hear it clunking around all the time. Does it not have big long perches? The welds on the perches would have to be broken for the rear to roll much.
How about a closer view of just one of the spring perches that shows the entire u-bolt on that side of the axle.
Your springs don't look kinked in the picture but trying to fab a traction bar with that dual exhaust is going to suck. I suggest you don't go wheeling or romp on the gas pedal until you get a traction bar on there.
Did they ever get your brakes figured out and everything tightened up?
I hear ya. Well, it turns out when they finally figured out the brakes when they were pulling it into the shop and my rear end was moving front and back...basically turning in a sense. My U-bolts were loose and the mech said I needed "ladder bars". Not sure what he meant but I guess they basically keep my rear end where it's supposed to be. Anyone know of any ladder bars? Would switching to a FJ40 stock axle fix everything or would it makes things worse?
ladder bar = traction bar.
You only need one, but you still need tight U bolts no matter what.
If you switch to a stock rear axle you will have a lot more headaches.
Stock center section is offset.
Yours is centered..
Look up JK Customs for a traction bar.
