Brake Master/Booster Swap???
Yuma Territorial Prison
Website
yuma4wheelers.com
Hi. This is my first thread on this forum.
I just bought a 1971 FJ40. I'm having trouble finding the master cylinder that was used on this LC. It was cobbled onto a Nissan booster. Both are in need of repair. I bought a secnd FJ40 for parts and laying on the floor was a mini truck master/booster with a 2 inch spacer on it. It was never put on the Cruiser because the Cruiser has 3 holes and the master/booster has 4 studs. I was thinking of using this on mt '71. Does anyone know if it will work? What is the most common master/booster upgrade?
Yeah it'll work, I have a 60/62 booster and master on my fj55. Its a bit easier swap cause its still 4 bolts all you have to do is widen the hole through the firewall a little bit. But if you have an adapter already then that should be just fine for you. Assuming that booster and master work.
Search "brake booster" on this forum and you'll find all you need to know on the subject.
I searched. Found nothing on the subject. At least nothing that pertains to my situation.
Thanks for your help clemson55. I'll be headed down to Harbor Freight to get a tubing cutter and bender to modify the lines to fit.
The other master/booster are in the '87 4X2 and I know those are in good shape. I'll use the adapter laying in the 69 FJ.
You can always get an adapter from Mark's Off-Road to mate the four-stud booster to the 3-bolt firewall. It also allows the booster to clear the rib.
a 71 has 3 bolts/studs that hold the booster...I guess 72 was the 1st year for 4 studs?
I picked up a Replacement Supra booster that dropped right in to my 72 :D
BTW,
They have drum/drum, disc/drum and disc/disc masters...make sure you get the right one for your setup.
manny
manny
I have a 71 FJ40 mfg'd in April 1971 which has the 4 stud booster. I used a booster out of a 90 or 91 Cruiser. You can also use one out of a mini p'up. If you get one from a wrecking yard, look to see if there is a spacer between the booster and the firewall. If there is, then get that also as you may need it to properly mount the booster to the firewall and the brake pedal. Also, the vacuum check valve on a lot of the newer boosters is seperate from the booster(unlike the 40's which had them on the booster). So you will also need to make sure that you get the check valve.
My '71 was manufactured in 11/70 and originally it has 3 holes, but someone drilled and mounted a 4 bolt Nissan booster with a Ford master cylinder.
I searched "mini truck booster" and there was a lot of threads, but not ones that related to my problem. Thanks for finding these.
I don't get why people get bent because someone don't search or they searched, as I did, without results and so they ask for info on the message boards. Maybe some people have better (or more important) things to do than to sit at a computer all day searching.
Maybe these issues should be in a forum dedicated to tech writeups. And title them appropriately. This should be titled "Mini Truck to Landcruiser Booster Swap".
Welcome!
I don't think you have a 71 FJ40. It must be a ?/70 titled as a 71? What does you door jamb plate say was the month/year of manufacture?
I have a 2/71 and it is 4 bolt. In all the reading I have done the consensus has been that 70 back has the single circuit brakes and 3 stud booster and 71 was the start of the dual circuit brakes with 4 stud master and the rib relocated. As stated before you may need to get the adaptor.
Welcome!
The plate says 11/70. Maybe mine was the turning point, because it has two brake lines coming from the master cylinder, but has a triangulated 3 hole pattern.
If your interested in a particular issue, it will always be in your best interest to perform a search.
If you don't, you might miss those key details that make a difference...
Think of it like Research :D
welcome to the community,
manny
Sounds like you have some sort of turning point or something there with your mounting for the brake booster. There can always be a way to either modify the firewall or make an adapter just keep hunting youll find a thread that is related somwhere in there. I know my friend has an earlier cruiser then yours 68 maybe anyway hes about to put on a corvette booster and master using an adapter, might want to hunt for that thread and see what it says.
Sounds like you have some sort of turning point or something there with your mounting for the brake booster. There can always be a way to either modify the firewall...
The firewall has been re-drilled for a Nissan booster. I'm going to remove the Nissan booster with the Ford master and replace it with a setup I found laying in my '69 doner rig. My concern now is, that the booster has been sitting for a while, un protected. The place where the vacuum hose goes has been left open. I live in Arizona and I know there is dirt in there. How would a person go about cleaning one out? Water? Compressed air?
The main thing you have to worry about is sand or grit next to the diaphram. This could possibly rupture the diaphram. The way that the booster works is it uses a vacuum and valves to push a diaphram in the same direction as your pedal. As the name implies, it boosts your pedal pressure. If that diaphram ruptures, your booster will not work nearly as well, and you will have a nasty vacuum leak to deal with (as you already know with your current setup).
With that said, I would try the water route first. Gently swash it around and then dump it. Make sure it is completely dry before you install it. You don't really want water sucked into your intake. I would stay away from the compressed air because of the rupture factor. Also, if you fill it with water and it leaks out the bottom, you know that your booster is bad.
Good luck!
I took out the other master/booster combo and I discovered this...
There were never 3 holes and the rib only comes part way up. Below is a picture of my VIN tag.
Anyway, I put it together and the spacer wasn't thick enough. so I added the nut's to the spacer.
Here's waht was in there before:
This truck was rolled doing 75mph around a 35mph curve.
Which frame rail is bent? I want to say the passenger's side...
