How do you know if your booster is bad or going bad?
I've been browsing a multitude of threads about brakes and am wondering if my 74 booster is an issue.
History:
swapped the knuckles out off a 60 onto my 74 front axle. new 60 loaded calipers and new 60 rotors. New brake lines. pulled front resid-valve. 4 new wheel cylinders on rear with new brake goodies and turned drums.
Brakes were ok, but neede a lot of force to stop. Rears locked up real early.
Just installed proportioning valve and bled rear brakes. Brakes are horrible. (regardless of valve setting) mushy and take a pump or two to get good pedal. Can't say I didn't mess up the bleeding, but I've done it a bunch before.
I am going to try to re-bleed the rears, as it's the most obvious culprit, but this whole thing has me thinking about the booster. From what I've been gleaning in other threads, the booster can go bad slowly so that it's not noticed?
What is the best way to diagnose a bad or worn booster???
When I shut off my engine I hear a loud hissing sound as something lets air out (booster, or manifold?)
If I do need a new booster, what is the BEST replacement for more stopping power?
MC Q:
Been thinking about swapping out my MC. Just noticed mine has a '1' on it. I assume this means 1" bore? if so, what is the advantage of going with an FJ80 1" MC?
I assume everything is stock 74 but who knows..... here is a pic just in case:
History:
MC Q:
I was told the one I had was that, but I should have confirmed before spreading misinformation
