brake booster again?!!
Huntsville,Tx
Ok I have called around and no one has a double diaphram brake booster for 1977 fj40. I got the choice of two maybe fits 1988-1992 or 1993-1998
the problem is that they both have a bolt head as the plunger instead of the horseshoe type with the cotter pin. Ok I tried to draw it ...not good.
The best that I can describe it, is it looks like a rectangle with one end open and the other end is welded to the bolt that goes into the brake housing. then a pin goes through both ends and has a cotter pin holding the plunger in place.
Please " I am not drunk it just sounds like it" I hope that is clear as mud?
My question is can I exchange my brake booster rod from the old to the new with out very much fab work?
The two brake boosters look the same as my old with the exception of the rod and the vacuume connection. I would assume that reducing the size of the vacuume hose would fix that.
Thanks for your advice...PS don't ask for picts I tried that with my steering issues not a good site.
Dennis
Why can you not use one from a 60 series....80-87?
Should be a bolt in deal...same mounting to the pedal, firewall and master....
If you are talking about the push rod from the brake pedal to the booster, then fabbing a new one wouldn't seem too difficult. There are other boosters that should bolt right up with no problems, like ones on mini trucks and Celicas.
Just remember with the Mini truck boosters that you will need a spacer between the firewall and the booster, or will need to shorten the rod between the pedal and the booster around 3/8".....
:beer:
reply
yes thats right about the 60 series but they could'nt diferinteate between the 60 series and the others. The big diff was that the one I have is 8 3/4 I think and the others were 7 ". I did n't know what to do and know if there was a diff between the size so I just went and bought the 88-92 I am not the best with fab work (no tools) basic stuff is no problem but if there is spacers and what not I don't know?
I will find out on wed. if it will work. I will see and try to get it right( along with my steering)
I'm sure that you tried CruiserDan, but in case you haven't, he may be able to help with an OEM unit.
Swapping in a booster from a mini truck is really pretty easy. Hey, if I can do it, anybody can. Cutting down the push rod was a simple task. I tried it first without cutting it, and guess what! The brakes dragged. So, I took a hack saw (tough cutting!) and cut about a half inch off. After that, it worked perfectly. Just remember the check valve. I got the booster and m/c from a 89 mini truck from a junk yard for $45. It all works perfectly. The biggest problem for me was the diameter. It was a little bigger, and barely cleared the clutch m/c. It still worked. I even left the m/c attached to the booster. Give it a shot!
Good luck! :cheers:
:confused:
I still have several rebuilt 76-80 boosters on the shelf.
So, Denofearth, did you simply pick up a '77 FJ40 booster or did you go with another application?
Ok !!
I got the booster that they sent. The problem was that it was half the size of mine! I called and told them to double check the product and they said yes that was the booster for a chevy metro!! I said chevy metro!!!???? This is deffinatly not going to work. They said that i could return it and try for another. I said what if i just tried this one out. They said if I dont hurt this one,go for it.
Well the damn thing works (with allittle cutting of the shaft) I think that I need to adjust the shaft a litttle bit more but , it works. Now for the steering
I got the universal joints from fire river and they are awsom they bolted right on and are tight.
Now I just need someone to go out and try the mods out with. I sure could use a friend or two!
Any takers?
Thanks for all the help and advice. Happy trails (or broken) are ahead !:) :bounce: :bounce:
Denofearth said:
...they said yes that was the booster for a chevy metro!! I said chevy metro!!!???? This is deffinatly not going to work. They said that i could return it and try for another. I said what if i just tried this one out. They said if I dont hurt this one,go for it.
Well the damn thing works (with allittle cutting of the shaft)....
:cringe:
