...guy installed Recaro seats in 2006 Cherokee. He was rear ended by so called street s**** racer on Subaru.......at over 100kms. The seats, famous Recaro seats broke off the rails. Rails were original Jeep and top side is Recaro. He ended up in hospital...The original lower part was not even buckled, but the top side made by Recaro was ripped off. The quality of the metal it was made was junk.
I also would not recommend installing so called aftermarket sports seats they are worth of s****!!!
....If they were indeed not grey market clone Recaro seats (there are TONS), but that said, there's more to having aftermarket seats than just buy -n- bolt.
Where the problem lies is the integration of the seat shell to vehicle. We talk plenty about not welding a roll cage to your sheet floor without proper plates to spread the weight, but it seems weight spreading in seat bases isn't thought through like some should.
Integrating a aftermarket seat to factory seat base (any brand) without doing the time to build that seat all the way into your floorpan is a bad idea, but luckily we aren't doing G-force situations in an 80 (mostly, unless acted on by another car, trail feature, or flat pushed out the back of a C-130).
A proper set of Recaro SRD's reside in my Sport Evo E30M3 clone, I know they will be safe in all but the worst accidents. I built them myself from the seat base to the floor, using the same seatbelt location (a whole other reason & world) as factory does with the Sport Evolutions did from the BMW assy line.
But back to the boy racer - the closest we have in an urban environment that a racecar design mimicks is NASCAR for the random G-force direction a car can take.
Look there & seats have a welded skeleton (steel or AL, driver pref), added floating pads & bolt to the tube chassis, no sliders as they build to driver size.
Aftermarket equipment is fine, if done right - sadly I doubt your buddy who was rearended would be in a different situation in a factory seat, they design the setups for rapid deceleration & not rapid acceleration to that level. Being rear-ended at a standstill from 75mph isn't the common wreck they design to mitigate.
---Broader takeaway should be that in keeping with proper bolt grades a washer that spreads load is a thought to keep, be it a simple donut or a chunk of plate to spread load like rollcage feet.
