I’ve watched CXracing intercooler mounted between frame rails survived gold mountain in bugbear. Not the best place but at the same time not the worst.
How about combining that i/c with a rock guard from Trail Tailor?
I’ve watched CXracing intercooler mounted between frame rails survived gold mountain in bigbear. Not the best place but at the same time not the worst.
To be fair Gold mountain is meh and it was only the one run![]()
True but rocks should be under the tires, not anywhere near the frame.
Ok....let's get back to Turbo Talk!
I heard a rumor it was going to be available this weekend?![]()
“Really a Toyota guy”...with 2 Raptors...not buyin’ it. Maybe you’ll Ecoboost the 80.Not necessarily
If I can get the bumper over it I can usually go up. This pic was a medium obstacle and its way higher than the axles. sliders are also way higher then the axles and we use the crap out of them.
The whole underside and front lower edge of the bumper up to where it bolts to the frame is all scraped up from ramping up stuff. That week I actually shifted the bumper up into the flares from banging the underside of it and had to loosen and realign it
On the Raptor the stock IC is mounted low between the frame rails and all the air for it comes thru the bumper
we make an aftermarket bumper that actually increases the frontal area and ducts more air to the stock IC. we were able to increase ground clearance a little, but not much without moving IC (and cutting frame horn).
many bumpers on the market (and any with winch option) require putting an aftermarket IC up in the grill (still AtoA). they claim that the IC is higher capacity as well (but im suspect). this works on newer vehicles because there is a ton of room in the grill to the radiator for newer regulations involving impact with pedestrians.
This is the trade off!
I would not be willing to loose ground clearance or move winches on my 80.
I immediately scratched anything from CX Racing off the list for this reason.
Ha
The Raptors are work vehicles but it is my daily and its awesome.
Maybe I should change it to "Historically a Toyota guy"
The 16+ Tacoma is a pile and it has made me a little disappointed in the brand.
Not to derail this topic---back to 1FZ turbos
GREAT news: Air to Water IC is on the Table!!
Not necessarily
