so I dont know if it was brought up but the kit should also come with the turbo badge for the grill, diesel guys cant have the only turbo badges
AND some big-pimpin, turbo decals for the outsides!
Hey good call bigredmachine!!so I dont know if it was brought up but the kit should also come with the turbo badge for the grill, diesel guys cant have the only turbo badges
now were talking
Hey good call bigredmachine!!![]()
You guys are too funny. The kit is not even completed/tested/ready yet and we are focused on badges, lol.
Well, we are all about as patient as a toddler and this way we aren’t bothering you about the hardware.....
Speaking of which, any updates?![]()
It's not even page 100 yet. I guess you are new here.
As with any of Joey's threads, this is just the warm up.
Anything I should remove or add?
- ACC headers/Y pipe
- Fuel Pump
@NLXTACY -
>>>>>To confirm, the turbo is going to nix the 2 primary exh mani’s as well as the Y - pipe the guys above just talked, yes?
>>>>>Also - I thought I saw you mention the idea of not doing a fluid intercooler, was that an idea that you’re still thinking on — or are you still back with the idea of a fluid cooler for charge?
I’d never asked, but assumed we were going to run the “log” type manifold w/ a single outlet & the turbo bolts to.
Also, I can’t find it now -but hoping the fluid intercooler is still very much a primary part in your setup / way you’re selling the kits when it gets to that point.
I would nix the Y-pipe, as the kits J pipe is going to replace the y. As far as the fuel pump goes, IMHO, if it’s not giving you an issue, I would leave it for now, or at a minimum drop it to a low priority on your list. Reason being boost is limited by what the ECU can keep up with.
I would add thermal shielding to anything thermally sensitive between the headers and the muffler to the list. Also, hopefully @NLXTACY will chime in; but I would verify fuel injectors are NOT being included in the kit. I don’t believe they are, but I’m not 100% on that.
@NLXTACY ->>>>>To confirm, the turbo is going to nix the 2 primary exh mani’s as well as the Y - pipe the guys above just talked, yes?
No. The exhaust manifolds stay. They don't even need to be removed.
Intercooler is NOT part of the turbo kit. At this point it may not come to fruition due to demand. BUT, if it does then it will be 100% an Air-to-water that sits above the valve cover. No other design is even a consideration.
FYI: I’m in for an intercooler. If your going to do it you might as well go all the way and have the best system possible. It seems silly to me to put a turbo on without an intercooler. Hopefully more people will be on board too! I’d rather not have to find a fabricator to build a one-off custom for me.
