body work!! YA!
I used those C-clips and rear sil for mine,
I cut off like half off of the top of the c-clips because I didn't feel a need to go that high. All I needed was the curved part.
There are some pics in my sig if ya want to see them installed..
has anyone used the quarter panel patches? I was looking at those and they are 95$ and the whole quarter panel is only 135$, so I would think it would be better to buy the whole quarter panel than just the patch. let me know what you guys think, I really like to hear what you guys have to say and I've gotten alot of good info from the one that have posted on this thread. thanks!
yes i did the $95 and did it twice Lots'a work had alignment problems :mad:
I found it easer to replace the whole panel. the whole panel went the better and took less time in the end and was easer to align I was tring to save a couple buck's :whoops:
don't rush it takes time make good welds if not stop and adjust what your doing,or take a brake can be frustrating :confused: lit your welds cool use a heat sink in back of your welding as not to distort the sheet metal my 66 40 was my first time too learned a lot ....Dusty :cheers:
one more thing, what do most of you use to cut sheet metal? die grinder, or angle grinder? or other?
Die grinder with a 3 1/2" cut-off wheel or a jig saw with a fine tooth bi-metal blade. The jig saw gives you much better control but is a lot slower. It also can not be used if there is something close behind what you are cutting as the blade will hit it.
Another thing I use if the metal is 18 ga or smaller is an air powered metal shear. Like a heavy duty pair is scissors! It cuts very smooth and fast but doesn't do sharp curves well.
i have a 3 spd floor shifter,new seal, nice alum piece that goes on trans with new boot and shifter with knob
must have a good clean ground have have a decent weld. nothing worng with a100 welder
Me?
what I was looking for was a pic of how far up the clip went, my64fj40 thats a good pic, you said that you cut some off, about how many inches did you cut?
I'd say a good 4 or 5 inches was cut off the top.
Actually I still got that piece laying around, I'm probably gonna swing b my shop tomorrow to pick up a part and ship it. I can get a quick measurement of the excess piece while I'm there.
so I found out what panels I'm going with. so should I replace the rear sill frist or the other panles? and thanks for all the help so far!
Do the sill first, it is the tie in point for everything in the rear. Then do the quarters. Don't forget to weld in some braces to support the tub before removing anything. You want to get your doors aligned properly, then weld n braces, then remove the sill. That way when you get everything welded back in the doors will still be aligned. If you have bad body mounts you will want to replace those first as they are critical to the alignment.
well I just removed all the body mounts, I'm getting ready to sandblast everthing. where should I put the braces at? should I put my hadr top back on?
my body was as shot as yours. I bought new panels from CCOT and they seam really nice. I ended up buying a whole new tub as there was at least less body panels to replace and it was straighter. Good luck
Jig saw. Faster, cleaner, more accurate, won't warp the metal from heat.
Also, as mentioned above you can't continuous weld sheet metal. Well you can but you don't want to. The heat build up will warp the panels, which would really suck if you buy new replacement panels. The idea is to tack it in, then keep making tack welds (with ample time for the metal to cool between tacks) until you have a continous weld. Its very time consuming and requires patience. Good luck!
do you guys think I would be better of buying another body? I add up all the panels I need and it came to over 800$. I dont know what a decent used body goes for, I dont think that I could get a body for 800$ could I?
