Body lift question
Union, Ky
I have the 2" body lift kit from 4crawler. I understand everything except for how to get to the front driver side bolt head that is below the battery. The only idea i have is cuting a whole from the front seeing as there are wires in the back, but not sure if that would affect to much structure either.. I can't find any threads that address this either, any help is appreciated.
I have a body lift with no problems, but that wasn't the question.
A picture would help to show your question.
Does this help?
It wont let me upload another image so I can only copy and paste.
the top head of the bolt is boxed inside of bracing, is it okay to just cut an access whole?
3f79ff17-3a3f-4105-acf6-c363bb39347a
Does this help?
Ya need pics for sure. Body lifts are great because it helps keep center of gravity low yet not cut up the nice body for tire clearance or lifting the whole truck for the clearance.
small body lifts do not cause issues...you should be able to get to all your body mount bolts. Remember you have to address the fan shroud when you do a body lift...no exception to that.
Thank you so much, Merry Christmas.
