- Thread starter
- #321
There are a few silicon removers out there but since you have an abundance of labour, you might as well try this solution. You can get the supplies at a market even in Malawi.
JonEakes.com > Jon's Fixit Database
Geocel have a product. ::: Geocel : Geocel® SILICONE SEALANT REMOVER :::
They are in the UK, and their stockist page doesn't have anyone listed, let alone international distributers.
I hope it comes good.
Eish Dan, sorry to hear.
Heatgun maybe ?
Dan just use a plastic hook to pull the most of it out, then use a stiff nylon brush to remove the residue, then some kind of cleaning solvent - the RB should not be affected, and you should be able to re-caulk and paint normally.
Don't blast the RB, until you have tried everything else.
All,
Thanks for the suggestions. We are gonna try pulling as much off as possible, then we'll try lifting it out of the seams with plastic knives (raided my
's picnic & camping supplies). Then the stiff brush and a little solvent. Don't want to mess up that RB. I talked to my facilities guys today and they pointed me to a supply of an acrylic seam sealer that is paintable, so we will try that after we get as much as possible of the silicone cleaned up. This may turn out to be only a 3-4 day setback
I did say these guys went crazy with it, right?
if I had someone put silcone in my seams between priming and topcoating!!!
mate!!!
