On cylinder 3 where the firing ring is you have pitting on the left side. Were you able to determine where the gasket failed?
No, not exactly. There were no real bad areas that I could determine (don’t have a ton of experience though). I’m not exactly sure that it failed. I was getting sputtering while cold after it sat for a day or so. I did the usual spark plug, wires, gas treatment job initially. It came back slowly. I then thought that I had a vacuum leak so I started putting together hoses since mine were already toast. I had the oil checked at a shop just to make sure for coolant (head gasket leak) and it didn’t show anything). since the thing had 318000 miles on it and I had another vehicle, I decided to tear into it. It has oil leaks at the valve cover, front seal, oil pump, distributed o ring, and maybe other places.
I was seriously thinking about a completely new engine but if I get another 50000 miles out of this I’ll be happy (that would probably take me 5 -7 years since I only drive it around locally).
Even worst case scenario, the truck needed all of this junk done and I wouldn’t get rid of it anyway.
Once it was apart, it looked better that I thought internally.
So, we’ll see in the long run. I’ve probably only got maybe $700 bucks into it now. Probably another $400 left. I figure if the block fails in the next few years, at least I can use the head since it’s been completely done.
Also, since the truck has been so good to me (I bought it for 5 grand 14 years ago) and it’s really not had any problems, I felt like I owed it to the thing to help it out
