- Thread starter
- #21
I haven’t used a rotary tool (roloc) on it yet. Only hand sanded with maroon (finish) 3m pad. Sounds like I should just finish with the pad (keeping dust out of cylinders) and then go from there.
Does it look like I should keep going or is that clean enough?
Factory head bolts new. I’m going to tap the bolt holes and let sit with wd40 and blow them out before the new bolts go in. Thank you for the advice.looks good enough. You running factory head bolts or studs? Use your vac and clean out the threaded holes.
I’m going to. I actually already wiped some of it down. I had a valve cover leak and it was covered with oil. Thanks for the info.Good time to remove your oil cooler, clean it and replace the O rings.
Don't test with more pressure than the oil pressure system is designed for or you'll make a balloon.....Try and pressure test your old oil cooler if you plan to re-use it. Last thing you want is a pin hole in it causing you grief when you get all done.
Cheers
How do you apply the hylomar? Is it a spray or paint?
I'd look at the contamination problem this way (and yes, it's better to disassemble the engine before cleaning the head mounting surface, but I live in the real world too and realize that isn't always possible): anything that gets between the ring and cylinder wall is likely going to do no more damage than the normal use wear contamination your filter is supposed to take care of.So there’s a bunch of debate on this one.
One group says:
no abrasives...I get it but I don’t know if I ever could get the surface good enough for a gasket
the other group says: rolok and 3m with rags in the cylinders (with grease or wd40)
I scrubbed for 5 hours with scraper, brass brush, chemicals, safety razor (plastic) and it still looked terrible.
Then my friend said to use a stainless steel cup brush on a drill. Cleaned on it for an hour or so...spinning with the brush, cleaning in between with acetone and wd40. Still looked like crap.
Used the 3m and it looked way better in 10 min.
The guys that say use no abrasive, how do you get it clean? I had no success.
As dirty as my block was, I don’t think I have any choice but to use abrasives.
I did a bunch of research before I started. Thats why I started using no abrasives. But as I went along making little progress, I knew that I’d spend months cleaning if I don’t use abrasives. I don’t know if I could ever get it clean (no matter how long) without abrasives.
x2: the gasket will "print" itself on the block.when I cleaned mine up I used a vacuum, scraper, and cut out Circles of cardboard to fit the cylinders to help keep junk out while cleaning.
Also, what you think is leftover gasket material is actually worn grooves in the deck from the head gasket heat cycling. Stainless against cast steel. Stainless is harder.
LMGTFY - Let Me Google That For You
For all those people who find it more convenient to bother you with their question rather than to Google it for themselves.lmgtfy.app
