Bleed brakes. The final solution ?
Are you adjusting the shoes with the rims bolted on ? Do it with rims/tires bolted on and rubbing is not tight enough you should be able to move tire but not spin it , once adjusted roll it back and forth in drive way applying brakes and recheck the drag, then gravity bleed it , top it up , crack all the bleeders, run back and fill master , let em flow and start closing them before master empties or keep filling it and close them 1 at a time closest first. I would always set a bit less drag on the fronts when adjusting shoes
Thanks
Yes runs and tires were off.
I will try with them on
Yes, do it with the wheels on.
In my opinion there are 2 REAL experts on bleeding/adjusting brakes on 40’s. One is @Poser and he is not responding to the thread. The other is @Pin_Head ...he is on this thread... listen carefully to his advice.
If you have one kicking around, a breast pump works as a good vacuum bleeder.
I give up ...
adjusted drums again...
Two man bleed again...
Bled master again...
Adjusted brake booster more...
still squishy
3 questions:
1) how many people do you have bleeding the brakes?
2) do you have the wheels on?
3) how tight do you have the wheels?
3 questions:
Two
Yes
Tight so they only rotiate about half a turn
One thing I will suggest is to go to the FAQ in the 40’s section and spend some time looking at the brake adjustment threads...ESPECIALLY...everything posted by @Poser . There is a ton of great info and some may give you some ideas.
It‘s difficult to say w/o actually being there but I would adjust them even a bit tighter than what you have. Take it for a drive and COAST to a stop. Get out and feel the wheels, if they are not hot, they are not adjusted tight enough.
Then keep bleeding, using the 2 man system. Make certain no air get into the line as your helper is pumping and of course dont get low on fluid in the master.
Its tough doing the brakes on a 40 for sure. Please do read Posers stuff in the FAQ. Priceless information.
Maybe it is a pedal height adjustment problem. How high is your pedal compared to the clutch pedal? How far do you have to press the pedal before the brakes start to engage? How much more do you have to push it until the brakes lock?
Clutch and brake are about same height
Need to press to at least 1/3 down
I can pump them up but once one lets go of the pedal. It then will then sink to floor.
Perhaps bad master but I have changed it twice
Maybe have a third person check all the line connections as you bleed ? It's possible you have a leak, but seems you would have noticed it by now.
Frustrating for sure.
A Harder project than replacing a clutch and head gasket combined ... sheesh
1. Adjust your pedal pushrod longer so that it starts engaging after about 3/4 inch of down travel. Make sure that it is not too long and engaging the booster all the time. The FSM has the procedure.
2. I originally asked if your brakes pumped up and you did not indicate that they did this. This is an indication that there is too much fluid volume in your system and it is usually due to mis adjusted brake shoes. The proper way to do this is to tighten each adjuster until it locks up and then back off 2 clicks. There should be enough drag that you can just barely make the wheel turn one full revolution with one pull on the outside of the tire. If not give it another click.
It could also be residual air in the system, but probably not, becaus it takes a lot of volume to get the pedal to go to the floor. After proper adjustment, if it still goes to the floor, bleed them again. Make sure the person inside puts some pressure on the pedal before you crack open the bleeder and be sure you tighten the bleeder before the fluid stops flowing. Pressurizing the system first compresses the bubbles and makes them move when you release the pressure. Also check that each wheel cylinder is fully retracted because they can be hard to bleed if the piston does not retract all the way. If you install the wrong cylinder in the wrong side, then the bleeder will be at the bottom and it will be hard to get all the air out.
If proper adjustment and bleeding don’t fix it, there are odd ball problems like ballooning rubber brake hoses that might be the problem.
If none of this helps, then you may have the wrong master cylinder that has a bore that is too small so it cannot produce the volume needed.
thank god it is FRIDAY and I can take another whack at this...
I can pump the brake up to hold in place,,,but it will then release once your foot is off and then will go to the floor.
The wheels perhaps go one revolution,,, I will try to make them even tighter.
Will bleed again tonight-- one more time......
Gin
Don’t give up on this and I would trust virtually no one to be able to do this better than you...the owner
These are really pretty dead simple...but almost no one actually has the experience to do this or the willingness to spend the time to do it correctly. We as the owners are about the only people left that are willing to spend the time to research, gain info from places like this forum, etc., etc.
Keep at it, keep asking questions and continue the march so to speak.
