Build BJ74 LHD 1HZ+T build
Nice cruiser! Lots of work went into her.
I really like the 13B-T also . I dont believe in overfueling them unless you upgrade the compressor and exhaust turbine or else your EGTs go sky high
Whether it is a Toyota Diesel or GM 12V71 was a TTA (twin turbo with aftercooler) now just a N for Natural . You may not notice the damage you are doing by overfueling but at the molecular level the engine does remember and when you least expect it driving to your mother in laws the engine will go puff or boom depending where you are on the throttle at the time.
Now dont get all excited about these 8-71 blowers (the roots are all fawked) . One of the motors in my personal junk yard.
well, we could debate 1HZ vs. 13BT for a long time. They are both better than a 2F (they don't have any pesky spark plugs). I have a 1HDFT, a 1HZ+T and had a 13BT. I like them in that order. The 1HDFT is the cat's meow. The 1HZ+T is silky smooth and quiet, is a modern overhead cam design, and has terrific power.
Work continued this weekend; Though much of my time was spent gathering more parts. I deleted the rear heater, and am using the "T" in the heater lines to supply the Disco Potato with coolant. The oil adapter for the oil sending unit is in, the oil line connected (Note: 36" line, more common, would have fit).
I was unable to actually bolt the turbo up as the adapter from Oz needs Socket Head Cap Screws (ie: allen bolts) in place of where the OEM studs hang on the 1HZ manifold, to fit in the counter-sunk holes in the adapter. I found high-strength ones at McMaster part#96144A265 (m10x1.25x40mm).
Also ordered up some metric studs: Exhaust / Manifold Stud 8mm x 1.25 Pitch [FST-030] - $1.35 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
and copper clad lock nuts: Copper Clad Exhaust Lock Nut 8mm X 1.25 Pitch [FST-031] - $1.35 : Himni Racing, Turbocharger, Turbo, Garrett, Turbo Kit, GReddy, Mazda RX-7, HKS, Apexi, TiAL, TurboXS, TurboSmart, Flange, Turbonetics, Exhaust, Intercooler, ACT, Intake
for the back of the Disco Potato; where the 5-bolt-to-3" VBand adapter bolts.
The V-Band adapter is stainless, but my 3" exhaust is steel, so using a steel v-band on the exhaust side.
Spent some time removing the 24-volt glow plugs, only to find that they are already 12-volt.
So, then removed the IP's fuel solenoid to find it too was 12-volt. Waste of time, but sorta nice that it was already converted.
The 1HZ is missing a couple bits and pieces; the clutch/fan/pulley are missing. I have a 1FZ fan, but the clutch doesn't have enough neck height to clear the main pulley. I think if I get a 1HZ fan clutch, the 1FZ fan should bolt to it?
Anybody have a 1HZ double pulley?
How about a used 1HZ fan-clutch? (I could rebuild with new fluid)
Was also missing the PS reservoir, but was able to modify an old BJ70 one to fit in the stock location.
The eBay-special aluminum HZJ75 radiator fits ok. The quality looks ok also. I'd have ponied up for an OEM, but I need to keep the budget in mind (I think I paid $225 or so... though looks like it is already discontinued?).
Power Steering High Pressure line, looks like an 80 Series version should fit (was recently used on a 1HZ-FJ60 conversion I saw, and fit great); or I could take the two fittings I have and get a hydraulic shop to make the hose (but it'd probably only save me $15, and would cost 3 hours of my time, including the drive back and forth).
New Timing belt, water pump installed.
Picts coming. Camera is at home.
nice build, congrats.
i am one of the ones that loves the 1HZ+T and one of the fuel that dislikes the 13BT ... enough to know i will not own another one (for long).
Peter and I have been on opposite sides of the debate before ... if we were all the same then we all would be driving a Ford. (thats what the masses drive, right?)
couple quick shots...
teh OZ 1HZ to T25 adapter; very well made piece. I'm impressed at how well it was machined and matched to the turbo. Should flow well.
The Ebay Radiator in all its shininess.
One more... the ebay special 5-bolt to 3" v-band adapter. Stainless. Also looks pretty well made. It came with the v-band and the exhaust side... though i bought another exhaust side in mild steel.
got a clutch here
might have a pulley off a PZ which is the same...
email me
waynesmith2501@hughes.net
to remind me in the morning...
Update. Short days and driveway work makes for slow progress.
The turbo has a 5-bolt to 3" V-Band adapter made of stainless. The exhaust is steel, so the new 3" downpipe with steel V-Band welded to it.
The turbo fits perfect with the 1HZ to T25 adapter. Like it was made to be there.
Some say the water lines are not required (The Turboglide kit plugs them), but it was easy to run them so why not. The oil line and return are plumbed.
I had illusions of grandeur when it came to the cross over pipe. I have a stock 1HDFT cross over ("Turbo"), that I had hoped to weld to the stock 1HZ cross over. After experimenting with MIG-ing aluminum (I was using a ready-weld with 4041 wire and 100% argon running off my 220v 185 MIG machine.), I found I could make good penetration, but the cast intake was pretty difficult to work with.
In the interest of time and such, I went with a simple mandrel bent connector from the turbo to the 1hZ intake. It's a compound twist, so it took some figuring.
was able to use an 80 series HP powersteering line. Why an 80 over the correct one? Napa had them in stock. It sorta works. Not great, but it will do for now.
Was also able to adapt a PS reservoir I had sitting around.
Things still to do:
-plug up oil cooler temp sender hole
-weld 1/8" npt to connect boost side back to waste-gate actuator (via manual boost controller from McMaster)
-3" 90-degree bends from air cleaner to turbo intake
-ebay 130a alternator
-fan clutch from G&S
-missing double pulley from ENS
-build (or buy) fan shroud
-Fuel Aneroid from All-American
-wiring: temp and oil senders are on the wrong side from the 13BT.
-Tach: oof. the 1HZ has a tach sensor on the pump. The 13BT used the tooth count on the flywheel. This might be tricky. Does anyone know the count per revolution of each?
ok... the 13BT flywheel has 275 teeth. EDIT: uhm... that's 275mm... still not sure what tooth count is. hmmmm
update to the update... the toyodiy site says "N=110" for the ringgear. I'm going to guess N is... notch?
What does a 1HZ pump send per revolution? (edit: and... the 1HZ sends 23 pulses per revolution. )
I got the small hot-side housing (.64 vs. .86) for early boost. I'm hoping the large exhaust and nice 3"-v-band adapter will help keep EGTs low. I have a Turboglide on my HZJ79, which I hear rumor is a similar turbo... sure looks the same.
Best deal I found was from these guys:
Garrett GT28RS Disco Potato Turbocharger - Enjuku Racing Parts, LLC
their website isn't terrific, so best to email exactly what you want, then include notes in your order.
Question Gifu ? What happened to the 13B-T ? If not sold I would make a deal!!!!!!!!!
The donor BJ 70 I think I may have test driven it a couple of years ago .
