Are you sure it's a Toyota dizzy? Not an old Delco.
If toyota, points or no points, 76 should be points
What is the carb? Is Aisan, check ICS, a bad one or ground will make a motor stop running at idle, but wit choke out it should run.
What sorta starters are you using? The old type or a newer (81-90) gear reduction style?
