I believe it was a Holiday Inn Express.Nor am IHave you ever stayed at a Holiday Inn?
I am not a fan of swapping side-to-side. The process to separate the Birf from the inner is quite violent and I'm not convinced pounding them apart until a snap-ring breaks, just to even out wear, is prudent.
Sounds like you wore that s*** out. Jebus.Just relating what I've heard others do and why they do it, Dan.
In my case, my recent adventure into the front axle saw the DS birf pull right off, leaving the half-axle inside the axle housing. Clip was still attached to the half-axle end. Haven't cleaned the birf up to see, but I assume either the cage was broke right where the ring is retained or the previous mechanic just shoved it all together and hoped for the best. They also didn't even bother with the spindle bushing or half-bushing and needle bearing. Ran at least 35,000 like that, so maybe Toyota should just drop the extra weight of that bushing and/or needle bearing? Probably not a good idea I suspect.
Then there was the apparently aftermarket spindle on the PS. It had the old bushing, although I've been told the 97s left the factory with the new half-bushing/needle bearing in the spindle. Tried dropping the new stuff in the spindle and NO GO so was forced to just keep the bushing for now and plan on replacing the iffy spindle with one that actually fits like factory. On this side, I did have to separate the birf, which took a couple of drops, but no special measures were required. In my case, at 180,000 miles, I simply decided, given the long overdue maintenance, to replace both birfs (as well as the drive plates). A bonus was that this took what feels like 95% of the slack out of the drivetrain.
Goes to show how tough these things are though.
Had to go home for the holidays on a gear oil transfusion. It was a mess and I knew as soon as it got warm enough to work in the garage, it was time to pull the trigger. Took me about a week, but I'm old and slow like the truck.
Take your time. That is part of the beauty of these things. They let you know what they need, but they start telling you way before you really have to do anything. It allows you to get a plan together and work your plan. That is part of what I love about them. I haven't gotten into the rear axle yet, but I have done a lot of other things to the truck so far and I am running out of things to rebuild and I lost track of exactly how much this has all cost.I was sweating bullets every time out of town for the last year since we returned from an east Coast trip to see the inlaws. The truck worked great, except it was clear the brakes needed lots of love before any return to Colorado, Used to visit regularly, but grad school and life has prevented a return for over a decade. Then about six months ago, the DS inner seal let go and it's been birf soup mostly since. Steering in parking lots seemed like I had the locker engaged up front at times, but I don't have lockers.Had to go home for the holidays on a gear oil transfusion. It was a mess and I knew as soon as it got warm enough to work in the garage, it was time to pull the trigger. Took me about a week, but I'm old and slow like the truck.
Need to follow up on a few things on the front axle, notably another drain and fill to flush more of that moly out of the inner axle bits and pieces, replace that funky spindle, and some torque rechecks and final adjustment on the wheel bearings. Then sounds like I should get on to repacking the rear wheel bearings, Dan actually sold me some of the stuff I have on hand for that back when he was, ahem, working.
'Cept now I may have to deal with brakes and bearings. I won't encourage any abuse, but I will say they can take it like champs. On nice roads like they're usually on in North America, I'll bet many things last far longer than expected . Service specs for Land Cruisers tend to presume a rather harsher environment. You can't go wrong by keeping them in the style they're accustomed to, but they probably won't hold it against you if you get a little rough with them either. They're game.
My objective is to get the beast thoroughly serviced before I get too creaky to deal with it anymore. Some days I think the body is telling me to hurry that up, but I'm already doing the best I can.![]()
I don't see anything specific in the maintenance pages of the FSM for a '92 about inspecting, replacing or regreasing the CV joint. But if you already have to do the bearing grease, why not take the extra time to re-grease the CVs?
BTDT. I too was a skeptic when Kevin suggested the birfields don't require regular maintenance and looked for a spec. Never found it, but you'd have a better chance than I. What he says makes sense though, there's nothing inside the birf cavity to 'service' if the grease level is maintained. I'm convinced there's no reason to get in there until the seals fail.
Two of us worked on a short-side with a steel pipe until the pipe ends mushroomed quite badly. Then we tried to knock it apart with a big-ass hammer and a drift. We never did get it apart. Probably one in a thousand and I hope no one else ever has that.![]()
