Isn't HEI a chevy thing? Or do you just mean high energy ignition (full electronic).
With 78 electronic ignition, this is how it will plug in:
1. You'll have a BY coming from your ignition switch (switched 12V). It will go to the BY on the igniter and the positive on the coil (there should be another BY come off the "+" of the coil to your starter motor, but it may be solid black as well.
2. Solid black from your Igniter will go to "-" on your coil.
3. R and W like thecrazygreek said, go to your distributor, should be a dongle/plug there.
4. The WB from your igniter is ground.
5. the BY coming off the ignitor goes to switched 12V (#1).
The BY wires make it confusing, but essentially you have BY between the starter and "+" on the COIL, and then from the "+" on the COIL it splits and goes between the ignition (BY should come out of the harness from the ignition switch) and then over to the igniter.
When I was going through this, I recall some frustration, but essentially you have signal wires (from dizzy to ignitor), ground wires, and 12V constant and 12V switched.
i got to a point where i was able to start and get the cruiser running in the "START" position on my ignition, but as soon as i let go in the "RUN" position, it would die - which meant I was cutting the switched 12V to the system.
FROM the starter to the "+" ignition coil is 12V constant power. From there the BY wire travels to your IG on your ignition switch (acting like an on/off switch on your house). From there it travels back to your igniter (switched 12V, meaning - it will only get 12V when you turn your key to start/run).
-dallas
-dallas
