It;s getting gayer. Bead blasted the intake and Painted a little.
I don't get it!
You'll want to balance the whole rotating assembly...crank, rods pistons...
do the flywheel as well.
These things weren't balanced well from the factory. Mine is earlier than yours but needed some BIG chunks taken out to balance it. I don't know what the weights were (but wish I did...)
You should be really pleased with a balanced engine. Have you ever seen/heard/driven a good rebuild with a balanced assembly?
I know my F purrs like a kitten and will pull strong while lugging over rocks @ 400-500 rpmI attribute a LOT of that to the balancing.
They were domed pistons and all that they could find was 040 over flat tops. I was on a time constraint and have regretted it ever since, the compression ratio would be significantly higher. I have my serious doubts about the shop that did most of the work though,
Those pistons are scrap metal...
So you stood by on the sideline and watched this take place and didn't pitch a bitch? s***!
your repeating history, go back to post #7
