So no updates since September? WTF? Dyno? I'd love to know how its running and the the actual specs on her now that she's finished.
It looks like you are getting a rich code at near idle speeds, based on the TPS postition and the low BLM at those posititions.
make sure the injectors are actually firing, as opposed to firing and leaking by. you can use a timing light hooked up, but aimed at the TB to see this. Have you checked fuel pressure? Many generic EFI pumps can put out enough volume at 45 psi to actually cause the 14psi-ish regulator to be overworked keeping the psi down to 14. Also make sure there is no restriction on the return.
Did you ever dyno Big Gay? If you did I must have missed it. I'm hoping to have my 2F back from the machine shop in the next few weeks. Should have it running sometime in May I hope. I can't believe how much i've spent on this project, but hopefully i'll only have to do it once.
Actually I'm going to go try to have the dyno done tomorrow.
Come on, inquiring minds want to know! Just how much gay horsepower and torque did it make?
Would you believe me if I told you 100 hp and 154 ft lbs of torque?
Yes I would, I thought you may get a little closer to the 150hp but over stock 125hp @ the fly, a 100hp @ rw on 35's is dam good.
I may have to build a N/A 2FE for an up coming 45 project![]()
