I'm looking for a standard sag steering box that has a better ratio. Mine howls like H**L when I turn at a stand still. Plan on installing a cooler for it, it is a new stock pump. I would love to have an AGR, but a supreme lack of funds hinders that. What years from what vehicles.
From what I can remember, the *ideal box to have, strengthwise & quick ratio (3 turns lock to lock), is a box that has the gusset & stamped "78" on the side. The info was from an old Four Wheeler article. You can clearly see the gusset here: However, I don't remember the vehicles they listed.... 70's Malibu or Chevelle?
The 4 bolt boxes are not always 4 turn. 3 bolt boxes, AFAIK are always 3 turn boxes. I have a 4 turn box on my 40, but after installing a high steer system last year, it is now only 2.5 turns! I really don't like that quickness on the road! I have got to do something about it before this summer.
I've driven a 3 turn box hooked to the stock steering wheel and found it quicker but not scary.
I wonder are the people who find it TOO fast using a smaller diameter steering wheel?
A smaller wheel would cause...hmmmm...kinda hard to explain...quicker response maybe?
The circumference of the stock wheel is longer so a 1" movement applied to the large wheel at the rim would result in less degrees of steering shaft rotation than a 1" movement applied to a smaller diameter wheel...thus more managable steering.
An extreme example would be a stock wheel VS a 12" dunebuggy wheel...
you are missing something here. the box turns 4ish turns lock to lock. Your new hy steer steering arms are shorter than your existing pittman arm. So you have reduced the needed throw on your box. Get a shorter pittman or go yell at the people who made your steering arms. They are probably too short..
BTW, the difference between the 3.5 turn boxes and the 4.5 turn boxes is nonexistant when you are driving straight down the road. The differences are at the ends of the pittman travel. As you get closer to the "lock" the ratio alters on the 3.5" box. that is why they are variable ratio boxes where the 4.5 turn boxes are not. They turn the exact same amount all through the sweep of the pittman arm.
I have a beefy looking 4 bolt box with 76 stamped on the bottom . its only 3.75 turns but works great. kinda jerky at speeds i have a longish pitman arm. all i need now is a borgeson shaft to replace my homemade one and som hydro assist
I used to have a 3 turn box when I had regular steering. I've never thought the steering was too fast. In fact, I really liked it for those times when you're having to turn quickly going up steep muddy hills. There are other variables that determine how "quick" the steering is.. Length of pitman arm is one.
