My understanding is that there is a foam strip on the top and bottom of the radiator.
On left and right sides too.
Good to know - none of those were replaced. Worth adding these now or just roll without?
Replaced my radiator this weekend with new CSF. 3 x flush with distilled water before installing the new Rad and filling with Toyota long life red.
curious why you flushed with distilled water?
Way off.Can someone summarize this thread? Looks to me like it ranks;
1. Toyota OE
2. Koyorad
3. blah-blah-blah....
Way off.
- Toyota OE, purchased from Toyota (made by denso, but not the same as buying denso from an aftermarket parts supplier) is overpriced and still has had some issues, mexico one comes with foam already attached for the low low price of $600
- CSF seems to be both the best priced, available, and the most reliable but be careful with shipping
- Koyo, Denso, and others have been ok but availability and batch quality seem to have been hit or miss with most people saying they worked fine but a brief period of people saying they had leaks where the plastic meets the aluminum right out of the box
- As of yet no mass produced proven all aluminum radiator
further:
- some have reported leaking at lower house with different combinations of radiators and hoses, does not seem to be a problem for those who use the adjustable McMasterCarr clamps
I would go back and look at some of the OE post, theres no consensus on Toyota OE quality. Availability has been spotty and sourcing questionable. The most unanimous vote from experienced people on here seems to be for CSF, koyo somewhere behind that, and Denso below that."Way off" ok, maybe my point. After Toyota OE, there's very little consensus on the quality of available radiators. With some shopping you can get the OE for <$400.00
I really like the idea of a quality aluminum radiator, but, the ones I can find that at least address quality/performance are $500+
Well, the thread topic is "Best Replacement Radiator for the Money". I got the CSF for $120 off rock auto, $280 extra is a lot to pay for the warm fuzzies that you bought OEM, but this is often the Toyota/Land Cruiser way. Its understandable that sometimes you just want to pay the money and not worry about it ever again.I would disagree on your assessment of the OE quality rads, those that are sold in the Toyota box I have not heard one complaint. (I read maybe the last 1.5 yrs on this thread), there are some people who have "heard" that some Toyota service departments substitute CSF for the Toyota version to their customers (I'll let others judge what they think of this practice, IMHO, not cool). Someone opined that the "original" supplier has changed, but I don't recall seeing a new OE radiator installed that has leaked in less than a year.
If the CSF are "pretty good" at ~$200 vs. $400 for the OE, I'm good for the OE version.
forum.ih8mud.com
Thanks for posting those pics.Toyota Dealership parts department, I've used for for 20 years, informed me, their shop uses CSF. But that is when customer would like a less expensive option than OEM. It all depends on what the service manager writes on the service order. The CSF needs foam swapping over. So the mechanic installing, does have more hours into the CSF job, if/when swapping foam. But it's fitment is good, although the goose neck are just a tad smaller diameter. So even with new OEM hoses (best) and OEM clamps (best). The do sometime weep just a drop or two at lower hose bottom fitting.
In OEM we've 2 choices in the USA (other country have other choices). One is U. S. spec, the other MX spec. Only difference (from what I can tell) is environmental standard (manufacturing process) they're built to. Function, fitment, look are the same. BTW the MX spec, is now coming with a rad cap. But I personally don't like the cap. I've tested them and cap seal to daylight, does not hold as well as a new OEM cap from Japan. With OEM radiator, hoses, clamps and cap fitment is spot-on and installation faster. No weeps or issue whatsoever.
Used car department uses a less expensive brand than CSF, I don't recall which one.
Foam:
Foam on sides and top is believed to aid in cooling. It helps direct air into radiator fins.
Note:
When replacing radiator. Best practice; new OEM coolant, thermostat & gasket and radiator cap. Any flushing should be done in advance.
Tip:
Clean radiators fins before begin job, if going to work in shop. Once engine radiator out, vacuum oil cooler radiator and AC condenser radiator, then below out with HP air. If working outdoors, than just wash oil cooler rad and condenser rad once engine rad removed.
Radiator fins need cleaning! Alert Alert Alert
I've a 06LC w/192K I just bought. In reading history I found PO complained of engine temp raising when both front and rear AC on. Toyota Dealership diagnosed with clogged radiator fins. Recommended new OEM radiator, $600 for the US spec Radaitor plus coolant and labor. They should have added...forum.ih8mud.com
Most important:
1) Burp air from the system over next few days. Make sure radiator filled to the very top and reservoir has proper level for current OAT and reservoir hose drops straight to bottom of reservoir. Also make sure reservoir hose has no obstruction.
2) Top transmission: best case we lose 1 or 2 cups. If 2003 up top while transmission fluid temp 97F to 105f is best (TSB: 97f to 115F)
Somehow this reservoir hose cap became plugged on rad side.
Foam on top and sides, bottom.
Foam on #1 skid promotes rust of skid if not replaced every 4 to 5 years.
Bottom foam breaks down over time, becoming a sponge.
New, cell are closed.
Many suggestion in this thread, on various foam options. Me, I transfer old to new, when not using OEM radiator.Just checked my radiator, it seems that the shop didn't bother putting the foam back. Any recommendation on the foam replacement?
