bent hardtop
northern utah
Hey all, sorry, i should have photos for this question, but I don't (yet) will post when i can get help getting the top sitting on the fj.
My hard top sits fine on the rear and on the windshield, but the b-pillar tubes wont go in all the way... i shortened them and they arent the problem,..in fact, when o hang on the side i *almost* can get it to lay flat.
This leads me to believe that the top has been bent in the middle.. my guess is that is sat in storage (outside) and had some weight on the front.
question is, how do i fix it? i have considered starting at the back bolts and installing them, working my way forward until i get them all in, but not sure if that will snap a bolt..
is there a better way to bend the front of the up up? are my assumptions correct? i cant see any other reason that the top isn't laying flat
thanks for reading this long winded post... this is really frustrating.......
You might have to unbolt the lid from the sides and lay it on a flat surface to check for a bow. I bought a dirt cheap hardtop many years ago that was disassembled and the fiberglass top was partially folded. I was able to straighten it and added some additional fiberglass on the inside and it’s been good for many years. I’d much rather go topless lol.
It could be getting hung up on the inner bottom guide ... need to get it to slide down straight ... if your doing this as a one man job it’s a pita
How rusty is your cruiser? Could be sagging in center of floors are shot or if somebody did a resto and didn’t make sure the things would be aligned with a top ... it can be fugged to fit doors and soft top
Try jacking it up in the center to see if you have mucho movement
Ok I was able to take some pictures… I mounted my doors today and they work great, but have a huge gap Between the top and door
You can see in the pictures that I have about 2 inches left to go down on the posts.. I don’t even know how helpful these pictures are
Yeah its bent. You can see it where the paint is flexed off the inside top around the B pilliar area.
Looks like somebody was lifting it in the center without support on the ends... they F uped the top ... more than one guy makes it soooo much easier
IMHO put the strap on the front and gently put tension on the front until it is squared again
thanks all.... im going to give a go! ill post results (hopefully positive) :)
Hey everyone, I’ve been stretching little by little that’s hard top the last couple of nights, and I’m almost flat… At least I’m now to the point where I can bolt it without an issue, I still have a little bit of been left to go on the passenger side post… Take a look
