So I have been having issues with my 80 dying after a few days. I changed the battery with a newer one and having the same issues.
I checked for parasitic draw and seems there is a constant -.35...which seems pretty low. I pulled each accessory I have on the battery and the draw did not change so it shouldn't be an issue with anything I have connected in the past.
When I get into the LC it is DEAD...no lights or anything. Jumps off no issues. Battery gets up to about 14 volts. When I turn on the headlights on bright and some fog lights etc it will drop to 12.5 volts and remain pretty constant. Turn the vehicle off and the batter is around 11.7 volts. Turn the key to ACC and the battery light is lit up.
I checked the alternator by using a multimeter on the negative post and put the positive on the alternator case...got a -.02 or -.03. When reviving to around 1500 rpms I get about -.04 or so.
Where is my issue?? Connections on the alternator?
Thanks!
Thanks!
