Battery Preferences ?
Boston
Website
www.burnmachinefilms.com
Ok I did some searching on here and couldn't seem to find anything related to batteries used in the 80 series cruisers ?
I have a semi stock 94 with no extra lights or electrical stuff but I do plan on adding some extra lights at some point. any recommendations on a good solid battery for cold New England ? I have a marine battery in my 60 and that's held up pretty well for almost 7years.
J
Lots of threads on this. I replaced my 5-year-old Diehard International with a Northstar X2 Power AGM battery from Batteries Plus / Batteries and Bulbs. So far, so good.
Best amps and versatility for the buck that I found was a Costco Kirkland dual purpose.
Yes! I knew that was coming I was just curious what people were favoring . i'm sticking with what I have.
Ok well then I won't bother telling you that I switched to an Odyssey 31M 2150 amp AGM and have been enjoying the extra reserve power for running lights, stereo, fan, and a fridge all night.
I agree this is the best #2 battery. The problem is, in an 80, the terminals will be on the wrong side.
For an 80 you need a reversed terminal group 27. These are not that easy to find. My take, is that AGM batteries are not worth the doubled or tripled price. But reversed terminal batteries from Costco work great and cost under $100. Just replace every 3 years and never worry about the battery otherwise.
I've had good service out of the Interstate Mega-Tron Plus Group 27F, it fits and hooks up without modifications. A good value at about $110 when on sale
Coscto Recently Changed their Batteries
The old ones (Kirkland Signature) were 100 month warranty prorated.
The new ones (Diehard) are 3.5 yr (42 month) free replacement.
I run them in all 4 of my Toyotas and have have very good luck. Around 7 yrs I replace them whether they need it or not.
Heat ruins batteries worse than cold, which is opposite contrary opinion.
had to add a short bit of cable to run my Kirkland dual purpose (that is a great feature even as a #2) but no big deal. Had one for more than 6 years, still running strong.
I have a Deka agm deep cycle for all my factory and accessory loads, with the exception of my starter/glow plugs. It works well.
I have an Odyssey for starting and glow plugs, it also works well.
There are a lot of good batteries on the market.
My costco has recently dropped kirkland brand in favor of interstate.
I ran the good 'ol diehard platinum in my 60--no problems, as should be expected from a $270 battery :o
Ran the Wally World Everstart MAXX in the 62 and LX and had great results in both, pretty hard on the battery and leaving the vehicle sitting for extended periods--no problem. At less than half the cost of Sears, I think this is my new go-to battery.
I have killed lots of interstates and Autocraft Gold (Vato Zone). Good warranty on both, but I'd rather have a battery that lasts than trade it in repeatedly for a new one.
J
Batts are consumables so get what's good for the pocket book. In my case, Interstate blems for $40 and I use them in all my vehicles. I did the Optima, Die Hard Platinum, etc route in the past and settled on this more affordable solution. Same goes with the engine oil, cheapest crap i can find but stay on top of the oil replacement regimen. These are 200,000 miles+ glorified tractors for crying out loud.....
Batts are consumables so get what's good for the pocket book. ...
Exactly, no matter how much you pay for them, they all are going to die.
In my case, Interstate blems for $40 and I use them in all my vehicles. ...
Agree, shop for best price and service, the local Interstate warehouse takes very good care of us. They sell blems/returns for $25 have run a bunch of them with great success, cant beat the value.
The proper battery is a group 27F. Since that spec was made battery tech has progressed, so now a 27F packs much more punch than it did then, for most, way overkill.
The #1 battery related issue that we see is connections, poorly added, etc. The most common is users putting in some boutique battery that doesn't fit, stretching and/or adding connections, causing failure of the alt splice, fusible links, etc.
Likely just a sticker change, Costco batteries have been Interstate/Johnson for a longtime, they come off of the same truck. There are only a few battery manufactures, so within the families, they are close to the same. The local Interstate warehouse is mostly full of black case batteries and a whole wall of stickers, depending on where they are going to be delivered, determines what brand sticker they get.
