Battery Dead
Alabama
I drove the rig home last night and i seem to have some wiring problems. On the way back, the fuse for the front lights went out:eek: . Did I mention it was 12 midnight, pitch dark. So, need to know what the prob is. I think the battery is bad (red optima). It doesn't hold charge. Everytime i turn off the rig, it barley turns over to start. Also the lights on the rig are all very, very dim. So I thought maybe the alternator is bad. Can i replace my optima battery if it truly bad? Thanks.
I would pull the alternater and take it to get tested. My battery ran for a long time for I figured it was another bad alt.
What does your amp meter do?
The amp meter stays in the center and doesn't move.
Not what I would expect unless it was broke.
Mine hung out just below the middle(to the Left) when it was my alternator.
where can i take the alternator to test it, should i also test the battery to see if it's still good? Doesn't optima have some kind of warranty?
do you have a volt meter? I would try charging it.
You can take it to advance, Napa, probably auto zone.
I would not suggest buying a alternator at advance auto. They had to order them and they came in the next day, but the guy told me "I'm not telling you to go somewhere else but i'll give you your money back" after the 4th bad one. Napa was alittle more but the fist one from them was good.
get them both tested, pull into an auto zone and tell them to test them.
I think you should be getting at least 13.5V to your battery with the engine running if the alternator and voltage regulator are functioning properly. The regulator may need to be cleaned/adjusted/replaced. Otherwise, x2 on the alternator advice.
You could also wire in a battery switch to isolate the battery from the system when the rig is parked (but I'd start with a fresh and/or fully charged battery). If the rig acts fine on startup when the battery has been isolated but sluggish/non-responsive when it hasn't, you may have a drain in your system somewhere. That's where it gets fun. :D
Optimas are good batteries; I'm running a blue top (marine starter) and yellow top (deep cycle) in my rig with no complaints. 'Course, they'll only go so far without any love from the charging system. ;)
Well I went to Napa today, the guy came and he tested my battery and said it needed some major charging. Then i cranked the rig and he saw how my lights were really dim. He said that most likely my alternator is bad. So, time for a new one. Where is the best place for a new one?
Napa has been good to me on my alternator. took like 5 days to come in though and was about double the price of advance, but advance could not come up with a good one after like 4 trys
Ok i just got my battery charged at firestone and the guy charged me 14.99. :o Anyway, i connected the battery and now all the lights are brighter, cranks in a quarter of a second:flipoff2: , and the turn signals actually blink. What i don't understand is i thought the battery is not even used when the rig is on, only alternator. But the lights still get brighter when i rev the engine. He wants to charge me 25 dollars just to test the alternator, not worth it IMHO. So, does this mean the alternator is still bad?
Sounds to me like your alternator is marginal. It's worth
getting tested - tho $25 sounds high for a simple alternator test.
The reason your lights get brighter when you rev the engine is
probably that your alternator is weak...higher revs means higher
alternator output. But a good alternator should put out about 14 volts,
even at idle. It sounds like yours isn't doing that.
But what caused the battery to die? The rig did sit during the restoration for about 10 months. Also the brake light sticks, so the guy who worked on it might have left the brake pedal stuck, causing the battery to die. But even though the battery was dead, isn't the alternator supposed to charge it back up, or can a battery get to a point where it has to be charged by a machine?
