baseline everything with synthetic fluid
CANADA
guys, looking for a list of products to basleline everything on my rig
i use mobil 1 synthetic 5w-30 motor oil but i'd like a list of what to use for the
automatic transmission/ transfer case
F/R diffs
brake fluid
power steering
i'm a fan of mobil one products but am looking for the best and a list from each of you and suggestion would be great, thanks
matt,
and one obvious ? is does any synthetic fluid in any of these areas a bad thing to use...keep in mind...i would do a complete flush on everything
Tranny -atf
Tcase/Diffs - Redline or Mobil 1 Gear oil
Brake Fluid - Synthetic Dit 3 equiv Valvoline
Power Steering Fluid - Synthetic Valvoline
Search is your friend. You will find as many opinions as there are syn products.
I am using all Amsoil execpt for the brake fluid(valvoline syn). I use Amsoil because it is a good product. They deliver to my door. It is also cheaper than most others because I have an commercial account.
You can change all of your fluids to synthetic if you want. I have replaced everything except the existing birf grease with synthetics. They will be changed in the near future. The most noticable upgrade yet has been the brake fluid and atf fluid.
Leavin the arabs in the dust....:D
Leavin the arabs in the dust too. All Amsoil fluids (engine/ tranny/ tcase/ diffs) for 3 years with no problems. I change my oil once a year as well so :flipoff2: arabs!
x3 for Amsoil
All three of my vehicles stem to stern. Everything Grease ,coolant ,trans's , etc ........ FJ40 too , [original drivetrain , and zero leaks BTW]
The more I learn about oil , even other manufacturers , the more that I'm imressed with Amsoils products.
Check out there new oil filters and bypass filters.....
If you want a Toyota to really run forever.....this may be the ticket.
I think alot of people are afraid that Amsoil is some sort of pyramid scheme , It's not Am-way.....no middle man , no hassle , not expensive , to your door.
I'll speak up for the Amsoil as well. Been using Amsoil for 10+ years on over 15 different vehicles.
Always a happy customer. And you can't beat the 10k mile drain intervals.
romer, i read somehwre that the power steering fluid in our rigs is actually atf, is that true? then what to i use?
Tranny -atf
Yes it's ATF. Use the same fluid that you put into your transmission if you want. There are several active threads right now on power steering fluid. Search results for "power steering fluid":
IH8MUD.com Forum - Search Results
