- Joined
- Nov 5, 2013
- Threads
- 60
- Messages
- 3,603
Well it's not much of a rebuild, but I took apart my malfuntioning I.S. and got it working. Perhaps this has been documented.
Drill out the 3 dimples holding the cover on. To remove the cover I clamped one of the mounting ears in a vise. I then used channel lock waterpump pliers to wiggle the cover off.
Clean up the plunger and the hole it resides in with waterproof sandpaper. Mine was full of crud. As you can see, the rod plunger was coated in 47 years of gunk.
I drilled a hole(3/32" bit) slightly smaller than my 2.5mm stainless screws and just ran the screws in. I didn't use a tap, the screws snugged up good and should be fine.
I measured the spring in case someone wants to replace one. About 28mm long.
The spring rides over the rod base. It's about 3.11mm.
It clicks when 12v's is applied now. Rod tip retracts 5mm.
